posted 01-29-2003 10:02 AM ET (US)
Masswhaler,Greetings from Duxbury, MA. I think you and I are working on similar boats right (16' blue interior) and I had the same thought to bring down the height of the bow rail.
I spoke to the guy at CMI who manufactures these rails and he said you would need to put the little bend back into the support legs and also that the lowering would require moving the attachment for the "hockey sticks" or side peices.
I think if you were to change to angle of the bend on these "hockey sticks" to be not as dramatic you could do it. I am still in the process of checking out local shops who could do this kind of work.
My thought was to lower not only the front rail, but also the two side rails as they seem too high also. These should be fairly easy to do, but the front rail is a little trickier.
I'll let you know if I find anything further out on this.
Regards,
Rich
