posted 01-30-2003 09:56 AM ET (US)
Kingsteven18,You don't mention which 16' you have. This makes a difference as to what Console you have on the boat and the length of the Steering Cable.
As DanT mentions, for the Eastport, he installed a 17' cable and it worked just fine. I would also imagine the Nausett and the Sakonnet would use a 17' also as they have the same, if not identicle, console.
As 15to17 points out, the 18' is what is used on the Montauks as their Cosole is a little different from the above models.
I would also think the length of the cable would be different from the ones above on the Tashmoo, Katama, Currituck, Bass Boat, as these consoles vary in size and placement on the boat.
Which model do you have?
