posted 02-07-2003 11:20 PM ET (US)
Howdy, HOH.Use jumper cables and first your boat battery, then, if needed, your car battery.
Connect the negative to the engine block. touch the positive lead to the large terminal on your starter. If the starter turns over with the boat battery it is a good battery and a good starter.
If the starter turns over with the car battery but not the boat battery you have a bad battery.
If the starter does not turn over you have a bad starter.
My guess is that the starter and boat battery are okay.
Now repeat, but instead of the starter terminal, connect the positive lead to the input (from the battery) terminal on the solenoid. Then hit your starter switch. If the starter turns over your solenoid. is good.
That leaves what I think is wrong, because it is the most common cause of your symptoms. Remove the negative lead from battery and engine block. Thoroughly clean both ends and the areas where they attach.
Most important! DO NOT buy or replace anything until after you have proven that "thing" bad. More money is spent replacing good parts than bad parts.
Red sky at night. . .
JB
