Topic: Do I need to worry about a cracked solenoid housing?
ShrimpBurrito |
posted 03-18-2003 03:08 PM ET (US)
As I was tightening up the bolts that attach the ignition switch leads, I cracked the #(@*$&* housing of my brand new solenoid. Part of the crack has probably a 1/32" inch wide gap, but the rest of it is closed. It goes the width of the unit (not the circumference), and there is a metal band that goes all the way around it to mount it to the housing. I expect this to keep the crack from getting worse, but do I need to worry about water intrusion or anything else getting in there?Thanks!
Al_A_Buy
posted 03-18-2003 03:19 PM ET (US)
Shrimp, As long as it is structurally sound and well secured, you probably don't need to worry about a crack in the housing. To weatherproof it, I would recommend troweling on some silicone sealant. Al W. |
Jerry Townsend
posted 03-18-2003 03:44 PM ET (US)
Shrimpburrito - as Al W. mentions, you should be alright and I second the silicone adhesive/sealant suggestion. Mechanically, the operation of a solenoid is not rocket science and there are no close tolerances or fits involved. With the metal band and the silicone sealant, you should be fine. --- Jerry/Idaho |
ShrimpBurrito
posted 03-18-2003 08:39 PM ET (US)
Al & Jerry - Thanks alot for the info. I appreciate it. I sealed it up with silicone, so hopefully that'll be the last I have to deal with it. |
