Topic: Removing old boat numbers
DaveNJ |
posted 04-13-2003 06:05 PM ET (US)
I removed old numbers and they have discolored the gelcoat. I did get all the old adhesive off. I have sanded the area with 220 - 400, but the stained number area won't go away. I don't want to sand through the gelcoat. Any ideas on how to remove this stain or is sanding the only way ? thanks, Dave
BabySitter
posted 04-13-2003 08:35 PM ET (US)
Dave,I had a similar spot where someone replaced the BW harpoon logo on my 18OR. What you may be seeing is the original gelcoat color that was protected from sunlight by the old letters - the surrounding areas have lightened from exposure ? JB |
skibis88
posted 04-14-2003 08:37 PM ET (US)
I agree with babysitter, you are seeing the original color of the gelcoat.How's your project coming along? I would be interested to hear how the Evenrude is performing after a tune up. Have you had the boat in the water yet? |
DaveNJ
posted 04-15-2003 03:41 PM ET (US)
Not in water yet. I am putting all new wood now. Still ahead: Varnish, White 3 piece rubrail, install, wiring, transom filler, motor mounted, steering system. Still much to complete. It will probably be June before I will be close to done. |
