Topic: ROD HOLDERS / INSTALATION
JOHN W MAYO |
posted 05-08-2003 09:22 AM ET (US)
I need some advise on adding a 2 additional flush rod holders to a 19 Revenge. I took the old ones out and they are 15 degree. To use them trolling is it better to have 1 15 degree and the other 30 degree on the same side or would you just add another 15 degree to each side? The Revenge currently has only one per side. Don't know the manufacture, but it is not Lee as I was will go back with for the new ones I will add. Any advise appreciated.
Tom2697
posted 05-08-2003 12:57 PM ET (US)
Just install the rod holders so the lines will have some separation. 0, 15, or 30 degrees don't really matter as long as the lines clear the other rods and their respective lines. It is usually more a matter of spacing and install angle from the centerline of the boat. |
