posted 05-26-2003 10:27 PM ET (US)
On a boat the "floor" is called a deck.Painting the cockpit deck of a Whaler is not a good idea. It generally decreases the value of the boat significantly and becomes a future headache to maintain. A painted surface subject to continual abrasion from shoes, etc., will not wear as well as gelcoat.
I would consider it only as a last resort for a deck that needed extensive repairs or whose gel coat layer was extensively cracked or otherwise damaged.
If you consult the reference section there are several articles on the 15-foot hull and you should be able to easily identify what model you have.
If you do happen to paint your floors, put some rugs or carpet over 'em to cut down the wear, eh?
