posted 05-29-2003 10:28 PM ET (US)
Let's see .......... If you move the engine forward 4 inches you should reduce the weight aft of the center of buoyancy because the engine will be closer to that point. I would guess that the change would be roughly the same as the change you would see if you tried standing at the transom and then moving 6 or 7 inches forward in the boat(assuming you're about 200 pounds). Probably not a lot.You will also reduce the total weight of the boat by the weight of the jackplate. If this is a manual plate, maybe 20 pounds; a power plate, maybe 45 pounds. You'll not see a lot of difference there either.
If you were running larger set back or had a heavier plate, maybe it would make a difference. The plate should allow you to run the engine higher up and reduce the draft at speed over that without the plate.
I'd keep it if you like the performance adder at speed. If it doesn't help when running, I'd take it off, but not expect a major change at rest. If you have a real problem with a heavy transom, its likely the extra 110 pounds of 4 stroke over two stroke that is the problem.
Full disclosure ...... I've never had a chance to measure the changes I've suggested are likely to occur. To this engineer, the analysis sounds logical.
