Topic: Plastic cutting board material
Aldog |
posted 06-05-2003 08:44 AM ET (US)
I need to go to work and stop all this reading and posting on this site. Another question. What is the white plastic material called that is used for the bait station cutting, and where can it be found? I need a couple of pieces maybe 8x10 or 12. Thanks in advance.
Robob2003
posted 06-05-2003 09:07 AM ET (US)
The one white marine plastic I have seen is called Starboard and should be available at any marine dealer. I got a small piece from a marine fabricatorIt can be worked with wood tools and I have used it for various functions where I wanted to replace a small amount of wood. Bob |
bsmotril
posted 06-05-2003 11:44 AM ET (US)
The plastic is Polyethylene. The difference between the Starboard type material versus the cutting board material is that the one designated for Marine use have UV light inhibitors added to the plastic. This will keep it from breaking down under prolonged exposure to sunlight. Starboard is good stuff, easy to work with wood tools and holds screws well. BillS |
alkar
posted 06-05-2003 11:56 AM ET (US)
Starboard is available from many sources, including the big marine mail-order houses and Cabelas & Bass Pro Shops. You might look at the Starboard transducer mounting plates - they're not much bigger than the size you're looking for. |
WhalinWilly
posted 06-05-2003 01:27 PM ET (US)
Aldog, Last year I bought a piece of starboard off of ebay. Since then when I need a piece I just email him and he cuts the piece a sends it out the same day. Starboard comes in alot of colors including; white, black, green, blue, and a tan that is real close to the desert tan of the older whalers. It also comes in alot of different thicknesses. Just email him and he usually responds right away. He is also very reasonable, I just bought a piece this morning; 3/4' X 6' X 19" black for $7.50. His name is Howard Everton and email is; heverton@msn.com . Good Luck Bill |
Aldog
posted 06-05-2003 10:21 PM ET (US)
Thanks Willy, Thanks guys. I have decided to add a couple of pieces to my new invention. |
WhalinWilly
posted 06-06-2003 01:50 AM ET (US)
Aldod, I just had to respond, Howard actually has a business and the more I can help him the better. I did contact him tonight and told him about this forum. I wanted to make sure it was alright to give his name here and he said he welcomed it. The bussinessis as follows;Norva Plastics Inc 2609 Monticello Ave Norfolk Va 23517 phone 757-622-9281 fax 757-623-2859 Howard Everton heverton@msn.com A really nice guy to deal with and very reasonable. Willy
WhalinWilly
posted 06-06-2003 01:53 AM ET (US)
Sorry for the Aldod, I really meant Aldo.....G Bill |
triblet
posted 06-06-2003 12:01 PM ET (US)
You can get it cut to size at TAP Plastics. They are nationwide, check the yellow pages under Plastic.There's another difference between Starboard and cutting board masterial besides the UV inhibitors in Starboard: the cutting board stuff has something added to keep it sanitary. Chuck
