posted 06-15-2003 05:37 PM ET (US)
I think it is normal for the navigation lamp fixture to have its temperature rise above ambient, but how much above ambient should it be?Excessive temperature rise could be caused by the lamp in the fixture generating too much heat. Often in devices like this there are a number of lamps which will fit in the fixture's socket. Each of these various different lamps will produce different amounts of light output, normally in proportion to the amount of current flowing through them. That current is in proportion of the voltage applied to them.
The maker of the navigation light fixture probably chose a lamp that would provide the proper amount of light specified in the regulations. Or at least one would hope they did. The range of the light's visibility for a legal navigation light varies with the size of the boat.
In many outboard boats the voltage available to the navigation lighting circuit is unregulated and is just the raw battery voltage subject to variation from the charging circuit of the engine. It is not unusual to see voltages as high as 15-16 volts.
The lamp is rated to perform at 12-volts, so when confronted wtih 16 volts is draws much more current, and it produces more heat.
I would recommend that you check the navigation light fixtures and confirm that you have the proper lamps in them.
Then I recommend you check the voltage being applied to them. If the voltage is too high, you might consider replacing the lamps with another style. It is not unusual for the lamps to be rated in small increments.
We used to always use lamps rated at 28-volts in circuit which operated the lamps at 24-volts. This gave much longer lamp life and reduced the temperature of backlit indictors which were part of switch fixtures that had to be pushed to operate.
Because of the requirement that the navigation light fixture produce a certain amount of visible light, you may not have such a free hand in chosing a lamp that runs at a higher voltage.
You ought to identify the maker of the navigation lights and check with them about the proper lamp to be used.
