Topic: Tach - Adjust or Replace?
newt |
posted 08-12-2003 08:30 AM ET (US)
My Mercury tachometer reads 800 rpm with the motor off. While underway, the tach appears to work fine, but I have no way of knowing if it is indicating the correct RPM's or 800 RPM's low. Is there a way to adjust the needle, or is the tach junk?
Dick
posted 08-12-2003 09:10 AM ET (US)
If your tach reads 0 RPM with the engine turned off the tach is bad. A reading around 1,000 is normal with the engine off.
lhg
posted 08-12-2003 03:38 PM ET (US)
Your tach is working fine if the needle drops to "0" when the ignition power is applied, before activating starter. |
newt
posted 08-13-2003 07:50 AM ET (US)
Thanks guys...you just saved me a few bucks! |
