ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods How do I raise bench seats?
Author | Topic: How do I raise bench seats? |
GUNFISH |
posted 10-25-2003 11:56 PM ET (US)
I would like to raise the bench seats about 2" in my 1986 13' so that I can put the gas tanks and battery under them. How do I go about mounting them higher? It must be sturdy . Any suggestions will be greatly appreciated. GUNFISH |
Sal DiMercurio |
posted 10-26-2003 12:17 AM ET (US)
Your gonna need 2pc of oak or teak 2x4. Remove the bench seat, take it out of the boat & place the bench feet on top of the 2x4 & drill it "EXACTLY" through the exsisting holes in the feet of the bench. I like "Cetol to finish anything thats going to get wet because it's an epoxy & holds much longer then oil. After their nice & dry & drilled, get s/s screws that are 1 5/8" / 1 3/4" longer then the exsisting screws that hold the bench to the floor or deck of the boat. Screw em in & your set. You will have a tough time finding any oak or teak thats a full 2" thick. Works great. Sal |
dfmcintyre |
posted 10-26-2003 07:27 AM ET (US)
I ended up doing something similar to what Sal described, only with multiple sheets of 1" black Starboard. Raised the console also, but with a slightly different method. Used multiple pieces of wood, laminated togeather to make two identical risers 4" high. Coated with epoxy (I used the West system) and sprayed with a polyurthane paint that was color matched for the console. That way I don't even have to coat it with teak oil, etc, and it looks like factory. If you want, I can email some photos if you forward me your email address. Best - Don |
posted 10-26-2003 03:26 PM ET (US)
I have never seen any reference to CETOL as an epoxy. The people that make it, Sikkens, refer to it as an alkyd oil. Cf.: http://www.nam.sikkens.com/product.cfm?product_id=3&product_category=exterior |
