posted 11-02-2003 11:47 AM ET (US)
Daddy,Some people say that you have to loosen the engine, others don't..
This might be due to the different engine manufacturers, I am not sure.
What I am sure of, is that I changed the steering cable on a 1980's 70hp Evinrude on a 1977 Montauk, without having to loosen the engine.. There was just barely enough room to slide the cable out, and then back in again...
Just Barely.... and I made sure that the cable was fully "IN"...
I always had play in 1978 Montauk... Not sure how much... I had the Teleflex Big-T helm which is what I assume you have... Whaler didn't start using the Safe-T helm until 1979 or 1980....
If you have the Big-T helm, you will either have to fill a couple of bolt holes in your dash, or make some kind of cover.. I (and a friend) made a cover out of Black Starboard, that was oval in shape to match the oval shape of the Big-T helm and 1" thick... This cover fit under the new Safe-T helm and made the Safe-T helm look almost just like a Big-T helm...
Worked great... I installed the new NFB system on his 1977 Montauk using the above method....
