| Author | Topic: Guardian gas tank / foam |
| JayR |
The floor is out in my 20' Guardian for repair. The foam surrounding the gas tank is wet. A tree had started growing out of the floor seam and had opened up a 3" fracture that was allowing rain water to enter. No longer being encapsulated, will the foam dry out? Can I get the water to flow to the lowest point and vacuum it out if I hollow out an area for this purpose? Would it be best to remove the foam and tank? I am leaning toward doing just that. Removal of the foam and tank, pressure testing the tank as well. What is the best way to remove the foam? Large sections can be removed but how do I remove the residual foam stuck to the hull and tank. What is the best type of foam to re-install? Thank you. |
This is an interesting question and a topic for a good discussion. Lately there has been what I would call a movement to encourage boat builders to NOT use foam to encapsulate aluminum fuel tanks. The publishers of the journal Powerboat Reports have been using their editorial pages to make a case against building boats with aluminum tanks and foam encapsulation. Their point of view is that use of foam encapsulation serves to retain moisture against the surface of aluminum tanks, and thereby increase the risk of corrosion of the tanks. On the other hand, there are many, many Boston Whaler boats built with aluminum fuel tanks encapsulated in foam which have not experienced unreasonable rates of failure of the tanks. Any aluminum tank that is 15-20 years old is probably nearing the end of its leak-free lifespan and is due for some repairs or replacement. How does one remove foam from around a tank? I think physical labor, scraping, etc., is the only way to get it out. Perhaps there is a solvent which could loosen the foam and not deteriorate the laminates. I don't know. If one has gone to the effort to remove a fuel tank and clean out the fuel tank cavity, would refilling with foam be the best approach? Were I in that situation I might consider alternatives. I have not seen first-hand how the tank actually sits in the cavity. Perhaps there might be room to support the tank using some stringers. You could make the stringers from a plastic material--say something like Star-board--or even from wood (if the wood were well sealed with several coats of epoxy). The goal would be to leave most of the tank surrounded by air, including the bottom panel, of course. Inclusion of some plumbing and hoses to de-water the tank compartment might also be prudent. I would plan on using a pump that could self-prime and tolerate a high lift. This would allow the pump to be located outside of the fuel tank cavity itself. Below I provide a hyperlink to an teaser for an interesting article for sale on the POWERBOAT REPORTS website regarding this topic: http://www.powerboat-reports.com/pub/15_11/features/5267-1.html |
| Chesapeake |
JimH: You raise an extremely interesting possibility - the notion of support by stringer assembly. With the exception that classic whaler owners (on this site) tend to be a bit anal about perfectly reconstructing to OEM spec, you'd think that someone on this site might have tried an alternative solution. The idea of an alternative assembly, provided it could have similar shock absorbing characteristics might be a design improvement - I don't know. One possible thought, lay down / epoxy several starboard stringer into "dados" in the floor foam. Support the foam sidewalls with a box made of marine starboard and backfill with foam against foam. Epoxy and screw filler strips along the inner walls snug to the tank dimensions. Is their a type of liguid to solid type of shock absorbing material that could be used between the starboard and the tank to keep it secure? Attached hold-downs to the floor stringers and around the tank to secure. Haven't thought this out well, but seems reasonable. Tom Clark, as our resident engineer and jack of construction trades might be able to weigh in on this a bit better. Tom? How do non-foam boat builders like Mako do this? Perhaps we need a Chain Saw Mako to experiment... a fitting end to such a vessel. :-) |
| Tom W Clark |
Jason, I don't have time right now for a full blown response. I'll try compose one this weekend. But for now let me point out some stuff we've talked about in the past here in the Forum. There has actually been a LOT of discussion about fuel tanks and their replacement. A search will yield much useful information for you. As Jim and Bob have discussed above, foaming in fuel tanks has long been common practice and one which has led to problems. Boston Whaler foamed in their aluminum (and plastic) fuel tanks for years but no longer does so. That should tell you something. If it were me, I would NOT foam in the tank. Be aware that your Guardian may have a more robust aluminum tank than what the recreational models received. What year if your Guardian? That may tell us what kind of tank you have. On new Guardians, thicker gauge aluminum and baffles are part of the fuel tank design. I think you should proceed with removal of your fuel tank and see what you have to work with. Be sure to read Cetacea page 70 for an excellent article describing the removal and subsequent reinstallation of a plastic fuel tank in a Revenge model. |
| lhg |
Is it possible to learn from Boston Whaler how the fuel tanks are being installed in NEW Guardians? Is foam being used? I think that would be the answer and methodology to use for a replacement. Perhaps someone in the C&GP division, or even Chuck Bennett, would give us this information? I have also heard RUMORS that BW is going to be offering a factory re-conditioning service to Whaler owners/dealers who want to have boats cleaned up and restored. I would think gas tank replacement with current Guardian methods, whatever those may be, would be of interest and of value to many who wouldn't want to tackle this ugly job. Has anybody else heard these rumors, and if there is any truth to them? |
| JayR |
Tom, the Guardian is a 1988 20'. The tank appears to be solid and free of corrosion. I am principally concerned with the waterlogged foam surrounding it. Any thoughts? If it pressure tests OK should I leave it in place and just address the wet foam? |
| Al_A_Buy |
Jay - When I did my tank replacement (1974 Outrage), removing the foam was the least of the job. Since the cavity is gel coated, the foam didn't stick to it and a wide putty knife did the job quite easily. As far as separating the tank from the boat, I stuck a screwdriver into the foam until it bottomed and measured the depth (about 4 inches). I then broke a SAWSZALL metal cutting blade to just shy of the same depth. I mounted the blade into the recip saw and held the blade against the tank as I worked around the perimeter. Worked like a charm. The hardest part will be breaking the adhesive on the bottom of the tank without damaging the tank if you intend to re-use it. Since I was replacing the tank, I simply laid a 2x4 across the floor and used a crowbar under the vent tube, braced on the 2x4. It took me (270-lb.) standing and bouncing on the crowbar for the tank to break free. Didn't really damage the vent fitting much. The problem with pressure testing the tank becomes plugging all the fittings and measuring the max 3 psi. Had a lot of trouble finding a gauge that had a center range that low. Even a 10 psi gauge is not accurate at that low of a pressure. Much more that 3 psi and you could deform the tank. Good Luck AL W. |
| JayR |
The tank comes out today. I think Tom was correct in assuming the tank is a more heavy duty version as it will support my weight without even flexing. Appears quite strong. BTW... I weigh 230 pounds. For it to not even flex under my weight surprised me greatly. |
| jxs226 |
Folks, Since Whaler supposedly is no longer "foaming-in" their below-deck aluminum gas tanks, do we know what new methods they've adopted for securing the tank and supporting the deck surface? I'm incredibly anxious to learn how they're now doing this, as I'm about to re-install a tank into a Guardian. Could differences now exist between the Recreational and CGP lines in how the tanks are secured and deck supported? Thanks. |
| lhg |
I'm still waiting to hear how the new Guardian tanks are being done also. Anybody know? |
| JayR |
A major surprise was awaiting me when I uncovered the boat this morning. The foam encapsulation surrounding the gas tank has completely dried. COMPLETELY!!! No sign of any moisture at all. So much for removing the foam and tank..... Change of plans. I am going to pressure test the tank in place. If the tank proves to be sound, I will devise a plan that will allow for inspection of the cavity and access for evacuation of any water that may enter once the floor is re-installed. I hope :-). Any thoughts or concerns??? |
| Chesapeake |
You may want to core out a section of foam just to be certain the drying out isn't just surface evaporation. Many people on this site have spoken in detail regarding the surprising water holding properties of this "closed cell foam." just a thought. |
| Tom W Clark |
Jason, How do you know the foam is dry "COMPLETELY"? By this I mean, you have no way of knowing if the core of the foam is saturated unless you cut into it, no? I'm not trying to sell you on unnecessary work; I just want you to be sure things are as they appear to be. That's not always the case. jxs226, Whaler has not foamed in their tanks at least since 1997, maybe longer. The tanks just sit on pads and are bolted down. The newer hulls have the fuel tank cavity in the hull formed much more closely to the shape of the tanks (or vice versa). There is less need for foam to fill the excess void between tank and hull. Larry, I do not know how CGP installs their tanks. Why don't you send them an email and ask? I do know that if they still foam in their tanks it is not simply by using the same foam as is used in the hulls. The problem they used to have is the foam that goes into the hull is much more dense than it would be if it were allowed to expand to its full size. Whaler Unibond hulls typically have TWICE the volume of foam necessary to fill the hulls, but because it is constrained by the clamped-together steel molds, the foam achieves far greater density and strength. In contrast, the foam used to surrounded the older fuel tanks was not constrained and thus expanded to its full or “free rise” state. This foam is soft to the touch and easily damaged. We often hear reports of this foam being wet and squishy. This is why I’m encouraging Jason to do a little exploration and think hard about not pulling his fuel tank. |
| JayR |
"Jason, How do you know the foam is dry "COMPLETELY"? By this I mean, you have no way of knowing if the core of the foam is saturated unless you cut into it, no?" Tom, I just found a small amount of ice (yes , it was cold here last night) at the very bottom of the cavity. So, it is not all gone, but close to it. I would assume, that too will be gone in a short time as this foam was saturated a few days ago. I must say I am not as optimistic at this point due to another realization... I don't see how this area can be made water tight. The fill hose and vent line chase is such that water will feed into this area no matter how well the seam is sealed. There is a drain from the gas tank cavity that feeds into the bilge area but it is at a height that is even with the top of the tank. Looks as though water was not expected to be absorbed by the foam and that the water entering the tank cavity was expected to flow over the tank/foam and out to the bilge. Well, let me tell you, it doesn't work that way. Water saturates the foam and then excess water vacates the area. Oh boy! So now what do I do? Re-foam and leave it as it has been for 15 years, or come up with a pump out system that can be utilized to remove the water on demand? I would rather the pump set up but am concerned with the tank eventually leaking and posing an explosive hazard. :-( What to do??? |
| JayR |
I am toying with the idea of re-foaming and covering the tank and foam with an Elastomeric roof paint as used on RV roofs. http://www.campingworld.com/browse/products/index.cfm?prodID=1414&src=SRCH&tcode=37 This would essentially seal the tank/foam from water intrusion and allow the entering water to flow out to the bilge as it was intended. What do you all think? |
| Tom W Clark |
Jason,. You've discovered another feature of the Classic Whalers, the bilge area and fuel tank cavity are all connected to some degree. You cannot exclude water from around the fuel tank. This is why the foam is a bad idea. It will get wet. I'm surprised by what you are reporting. Do I understand you correctly that the foam was formerly totally wet and now is nearly totally dry?! Even the completely wet foam from CSW is still somewhat wet a year later after sitting in my heated basement. Your foam must have suffered severe cellular damage to be able to take on and then loose all that water. I think your best bet is to remove the tank, clean things up and reinstall with some extra padding and not use any foam. Even Whalers with foamed in fuel tanks have extensive parts lists of different pads, braces and straps that mechanically retain the tank in the hull. I would think a little modification and reinforcement of those supporting parts could be done fairly easily and the foam simply forgone. |
| lhg |
I think Jason's experience is telling. I, too, have discovered that by leaving the floor access covers open during periods of storage under a full cover, or in a garage, that the foam seems to dry out. Maybe it is intentionally not closed cell foam? The BW Owners Manual indicates "It is normal for some water to accumulate in the tunnel and fuel tank areas". They also say the foam used is "gasoline impervious". There is no question that water gets into the gas tank cavity, mostly by overflow from the rigging tunnels and full stern sump wells. Some may also get in from washdown and rain. Although the hulls are self bailing and generally keep the floor dry, if there is standing water up to the top of the sump covers, water will have already overflowed into the gas tank cavity. This is why I keep plugs in, and use bilge pumps instead, to keep the tunnels dry. This subsequently keeps the gas tank cavity and foam reasonably dry. |
| JayR |
Tom, If I do as you describe, the drain from the tank cavity, 2" below the floor would allow 10"+ of water to remain around the tank at all times. Unless, I also install a sump pump in that area to remove the water. Being an enclosed area, that could lead to a potential explosion if, or I should say WHEN the tank leaks fuel. The only other possibility is to use an explosion proof, self priming pump that can be externally mounted with just the suction hose below the floor. I'm certainly perplexed..... |
| JayR |
Larry, I believe you are correct. This foam was allowed to expand to its' full potential and is much more porous than the foam within the hull. Evaporation more likely in this state. I do not believe it has lost its' structural stability at all. It is very strong and very difficult to remove. Certainly strong enough to support the tank without a doubt. |
| Tom W Clark |
Jason, Larry, The foam used around the fuel tank is not some other type of foam. It is not intentionally an open cell variety. As I have said, it is the same polyurethane foam used in the hull except that it is free rise and thus not as dense. It is still closed cell foam so if Jason's has absorbed water it is because the cellular structure has broken down. This should not come as a surprise based on our experience with CSW. We know that closed cell foam can break down and absorb water. Furthermore, and contrary to what has been reported elsewhere, the foam can absorb water without being forced into it by water pressure caused by running a hull at speed with a rupture of the hull skin. Obviously the foam surrounding Jason's fuel tank never had water "jetted" into it, it absorbed it. Jason, Where did this Guardian spend most of its life? Did it live in a climate that was subjected to severe freeze/thaw cycles? Yes, if you do not use foam around your tank there will be water down there, but there already is. As Larry has pointed out, this is a very good reason to keep the drain plugs in and keep the bilge pumped out. I have always recommended keeping the bilge dry. The idea of leaving the plugs out for self-bailing purposes does not appeal to me especially in salt water given that you will effectively be soaking your fuel tank in a flooded compartment, foam or no foam. You need to think of your fuel tank cavity as part of the bilge. That is what it really is. What about installing a drain tube at the bottom of the rear dam of the fuel tank cavity? That would allow the water from around the fuel tank to drain to the bilge sump and be dealt with by your bilge pump. I think your leaking fuel tank scenario is no different than a leaking fuel tank in any other 20' Whaler. If a fuel tank leaks, the gasoline is going to wind up in the bilge sump sooner or later. |
| where2 |
Methyl-ethyl-keytone. That's how you remove the foam around the tank according to the shop currently working on a 25' Frontier. If you plan on having Florida Marine Tanks build you a new tank, they need 4 weeks lead time. (spoke to them about a month ago). How to install new tank: Foam it in... It's a tried and true method, and generally you get 15-20 years of good service out of this method. Exactly how often do you repower? Repowering is much more expensive than re-tanking! Few seem to flinch at repowering prices... A new 140gal tank from FMT was quoted at $1400. A pair of 150 4stroke Yamahas was quoted at $20k... Tanks are cheaper than a trailer! Now for a rebate: Call your local metal recycling center and ask what the rate is for aluminum, and carry your old tank to them for recycling, and get some $$$ back... |
| JayR |
Tom, The boat spent its' life in the Everglades National Park. I don't think it gets too cold there... As for considering the tank cavity as part of the bilge, that's fine but it is lower than the bilge and will not empty at least 60% of its' contents being the bilge drain is 8" higher than the lowest part of the gas tank cavity. Perhaps a completely new drain can be installed from the gas tank cavity through the hull. Bad idea??? |
| logjamslam |
Jason, I don't know If you have already got your fuel tank problems figured out. I have some photos of a pump system that I am using with a hand pump. It seems to work pretty well; both water and gas. Let me know if you want me to E-mail them to you. Greg |
| JayR |
Yes, please..... The more I see, the better I can decide a plan of action. |
| logjamslam |
Jason, I sent the pics last night let me know if they didn't show and I'll try something different. Greg |
| JayR |
I got them. Thank you! Very nice application. Clean, neat and easy to use. Nice job. If I remove the foam, I will definitely consider a similar installation. |
| foursonsmarine |
I TALKED TO WHALER'S COMMERCIAL DIVISION YESTERDAY. THE COMMERCIAL DIVISION STILL FOAMS ABOUT HALF OF THEIR TANKS IN. THE OTHER HALF HAS BRACKETS WELDED TO THE TANK AND ARE BOLTED TO THE STRINGERS. THEY USE REGULAR 2LB DENSITY FOAM FOR THIS. THE HULL USES A MUCH MORE DENSE FOAM. |
| lhg |
Thanks for that information. It would sound like the Guardian models are still getting the same foamed-in-place tanks. Which of the commercial models have stringers? |
| foursonsmarine |
I SPOKE INCORRECTLY WHEN I SAID STRINGERS. I USE STRINGERS ON MY BOATS AND THAT IS WHAT I AM IN THE HABIT OF SAYING. I MEANT THE RAILS OF THE INNER LINER. THEY ACTUALLY DRILL AND TAP THE RAILS FOR THE TANKS THAT ARE BOLTED IN. |
| foursonsmarine |
Back to your original question, if you decide to re-foam, whaler uses a 2lb closed cell pour foam. You can get this from West Marine, Boaters World, or probably any marine supply. The new foams are supposed to be virtually waterproof. |
| eric_from_MD |
Jay- I have posted this a long time ago but will mention again what I did. Let me start by saying there may be better solutions to your problem but this was the solution I chose after much input. I had a 1988 18 guardian with the exact same situiation you mention. Good Luck |
| JayR |
Thanks Eric, I am planning on doing something very similar but not as permanent. I'm not going to glass the tank as it is a very solid and thick walled container. It is not corroded at all. This is in a Guardian 20" and appears to be a much thicker wall than I have seen before. I am going to pressure test in place and re-foam if all is well. I will then paint the tank top and exposed foam with an Elastomeric roof paint. This will in effect seal the whole thing as you did and hopefully keep the water out. I also plan on foaming the gas fill and vent lines where they come up from the deck and enter the gunwale. There too it will be waterproofed. I'll keep an eye on the area through the deck plates and if I see a problem, I'll sell it.... Hahahahahahaha! Just kidding of course. I am pretty confident this will suffice. The floor is coming along. All plywood has been removed and I will be re-backing it starting tomorrow. I'll keep you all posted. JR |
| daverdla |
I don't know if this would help but you could try a vacuum test instead of a pressure test. I use a might-vac for bleeding brake lines. The unit I have does have a gauge on it. Dave |
| JayR |
Looks interesting. I could use it on my motorhome's brakes too. Damn thing has air in the system that I cannot get it out. I don't see any price info. What does it cost? |
| andygere |
I think Eric From MD is on to something here. Instead of trying to keep the water out of the cavity, why not protect the surface of the aluminum tank from corroision directly? In the water industry, epoxy coatings are used on water tanks, treatment basins and pipes, providing corrosion protection with a design life of 50 years or more. Why does Whaler (and the rest of the boating industry) install naked aluminum tanks with no external corrosion protection? In my opinion, the foam is not the problem, it's the lack of a protective coating on the tank itself. I think that simply accepting a 15-20 year life on a fuel tank foolish, but the industry has convinced us that it's the best it can do. When (not if) I am forced to remove the floor on my Outrage 22 Cuddy and replace the tank, I'll be sure to have the new tank epoxy coated to ensure that it outlives the rest of the boat. Based on info provided here, I conclude that the foam does not do much structurally to secure the tank, and its purpose is most likely to prevent the accumulation of a large amount of water around the tank. |
| lhg |
Regarding the question of why didn't they build Classic Whaler Outrage/Revenge models better (such as non-draining tank cavities, better tanks, and tank floor covers) one must remember that all of these boats were designed in the late 70's and early 80's. All of this before knowledge that the company would be sold several times over, design vocabularly changed (making the old boats more popular than they ever dreamed of), and before the internet discussion, photos and used boat markets. Also remember that at the time, these boats were extremely expensive to buy already. My guess is that a 20 year life span on a tank, or tank cover, was considered the right economic/cost containing decision at the time. Dougherty and others probably figured these same buyers would be buying a new Classic Whaler in the future (the 1990's). But as the ready supply of new models that we liked disappeared, we didn't, and instead decided to keep our existing Classic Whalers, or find used ones. Plus, a newer, younger almost cult following is developing besides, which would include many here, now interested in keeping these boats on the water for many more years. So the whole gas tank design decision making process is now being re-visited, with it's resultant shortcomings. But I still say that these decisions were not all that bad, as the new "Classic" C & GP hulls are still being done with the same gas tank designs. Does anyone know what specific improvements, based on all of this experience, have been incorporated into a new Guardian's fuel system? |
| daverdla |
Jay, I think it was around 30 bucks. Make sure you get one with the gauge. I've found that it works for any bleeding job unless a pressure method is recommended. The clutch slave on my porsche requires pressure. I tried the mighty-vac first but no luck, had to use the pressure method. The brakes and clutch on an MGB can be bled with the mighty-vac. It really makes it a quick one man job. I'd imagine trailer brakes could be bled with it. I was wondering if it might be useful for a hydraulic steering system. Dave |
