| Author | Topic: RPS Risers |
| whalerajm |
Several weeks back I was looking for info on using Risers to raise RPS to get more room for larger tanks...Whalersman (Joe) helped me out quite a bit... I've made 2.5 inch risers out of TREX decking material...The natural color is very close to the teak on my Montauk, the material should be impervious to sun, saltwater and freshwater (or so I was told)... Before I install the risers and the RPS, has anyone tried using TREX for marine applications? Any problems?
| JayR |
I used Home Depot's Fiberon. Very similar. Worked out great and has been in uste for 3 years. Not stains discoloring cracking.... no problems. |
| dfmcintyre |
I've used Starboard for some seat risers, and laminated wood that was covered with a coating of epoxy, then painted same color as the floor for console risers. No problems with either set, although one winter project I'm considering is replacing the Starboard with laminated wood to match the console risers. One thing you may want to consider is changing angle of the seat, very slightly lowering the rear of the seat. I've always felt that I'm sliding off the front of the seat. Sat in a friends RPS that he added a set of angled risers to it, and found it very comfortable. Don |
| Buzzorouter |
Made mine out of 1/2" Stainless. Thought they would sink the boat. Went up 3 1/2". I can put the 19 gallon tank under now. The 25 will fit but I had already put corner mounts for the 12. The 19 is the same dimension except higher. Raising the seat also negated the need for a pole for my boat cover. |
| whalerajm |
Thanks Guys, Never thought of angling RPS Risers...too late now that they're done, maybe next set! They actually look great! Trex natural color with a few coats of gun stock oil...Identical match to oiled teak on the boat! Now I just have to tighten up old RPS screw holes in deck, find something to make newtank mats out of, reinstall RPS, and put my shiny new 13 gallon tanks under the seat...I can't wait for Spring! |
| ratherwhalering |
I've often wondered why these are not installed under the seat, as opposed to on the deck where they can be seen. I've considered this idea on several occasions, and will probably get to it this spring. Has anyone tried this method, and does it work? |
| whalerajm |
Ratherwhalering, I'm not sure I understand what you mean when you say you wonder why "these" are installed on the deck and not under the seat. If you are referring to the RPS Risers..My intent was to raise seat to fit larger fuel tanks, not sit higher up or angle seat. I suppose there would be some way to raise the seat from below seat (as oppsed to deck) but this would only serve to raise the seat and not give you more room below seat. I also believe there are several different size and style variations on the Montauk RPS's depending on year. |
| Tom W Clark |
Rob, Actually there have been very few variations of the classic Reversible Pilot Seat (RPS) over the years. They have all been the same size and the only significant variation has been the construction of the seat back which varied from oiled teak to varnished mahogany to fiberglass. I believe Andy is asking: Why not put the spacers between the top of the legs and the bottom of the seat cushion instead of putting the spacers under the bottoms of the legs? (Either way, you wind up with more space below for a larger fuel tank or cooler.) Andy, The reason is simple: If you put spacers between the seat cushion and the tops of the legs, you loose the notches that hold the pivot frames (stainless steel bars) that hold the seat back in place. The tops of the RPS Z-legs have notches in them that the pivot frames rotate in. The seat cushion has low friction plastic pads that contact the tops of these pivot frames and allow a controlled but smooth rotation. The relationship between the tops of the legs and the seat cushion bottom is pretty precise and putting a spacer in there would necessitate the spacers themselves having notches or blocks to position and control the pivot frames. It could be done of course, but it is more work than just putting them under the bottoms of the legs. It should also be noted that the very first RPS Z-legs were made of aluminum and they (along with the first of the plastic Z-legs) did not have the notches for the pivot frames. Location and control of the pivot frame pivot point was achieved via little blocks of wood screwed to the underside of the seat cushion. This technique could be used by someone who wanted to put spacers between the tops of the Z-legs and the seat cushion itself. |
| ratherwhalering |
Interesting, Tom, thanks for the reply. I have never actually removed the seat from the RPS legs, but now I have a pretty good understanding of how this works. I gather that if the notches that hold the piviot frames are too shallow, it will bind the tubing when the seat is tightened down, and if they are too deep, the tubing will rattle around and defeat the purpose of the low friction plastic pads on the seat cushion. I'll try to follow up this spring when I get to this project. |
| Tom W Clark |
Rob, There are some good photos of an RPS that has the plastic Z-legs without the notches for the pivot frames (and the plywood blocking necessary to locate the pivot frames). These are form Archie Cassidy's 1978 Montauk and he has some great photos of that boat here: http://www.seaofquilts.com/whaler.htm |
| ibeenfishing |
JayR You said you used Home Depot's Fiberon. I just went to Home Depot to try and buy some. They didn't have it and had never heard of it. They said it wasn't in their data base here in Tx. I was wondering is this available only in New England, is it in the Building Material catagory. Can you elaborate more on the product. |
| lhg |
I used teak to raise mine 6" and they are beautiful, I think. The raw material was really not that expensive. On one boat I have them oiled, the other varnished. |
| Slippery Eel |
lhg, I am in th eprocess of planning a 6" lift using teak. Did you offset/extend the length of the blocks to compensate for the additional weight on the seat while leaning back on the RPS with the added height? Did you make the blocks out of solid teak or build it up using multiple pieces? Any pictures? Thanks |
| lhg |
Slippery - I'll see if I can describe how I did it. A while ago I sent some photos of these to Whalersman. Joe, can you put them up somehow? Anyway, it's quite simple. Under each leg, looking at it from the side, the riser assembly is an upside down "U", with two blocks, 3"(wide) x 4" in plan, and 4" high, spanned by a top beam. These riser blocks can be laminated up any way you want. I used two 2" thick sections. Then, spanning across the top of these, is a "beam", also 2" thick, only 1/2" longer on each end than the RPS leg dimensions. The seat leg sits on top of this 3" wide beam. All vertical and horizontal exposed edges of the blocks and beams are 1/4" 45 degree beveled. The entire assembly is rock solid and stable, with no movement or deflection. The riser "blocks" each have two deeply countersunk 1/2" dia holes, exactly matching the hole pattern from the RPS in the boat floor, and the blocks, using 2" long screws, screw into the original holes in the boat floor. When you drill these blocks, drill 1/4" dia from the bottom of the block, all the way through, for matching accuracy, then countersink 1/2" from the top as needed. The top spanning beam then screws into the top of the blocks with two 3" long screws, countersunk flush, underneath the seat leg so they don't show. Then the RPS leg screws into the riser beam with 1 1/2" or 2" screws. All screws #14 (1/4"). Underneath my raised seats I have mounted the angled Whaler starboard cooler cleats in black, which securely holds, without bungees, a tan pleat cushioned 72 qt Igloo cooler seat, which can be pulled out for additional seating, dry or wet storage, etc. The 6" height is adequate for the cooler to fit. My consoles are raised exactly the same way, except with different dimensions, obviously. This design looks like factory original Whaler quality. I have not had a problem finding teak in thickness up to 12/4, and everything in between 4/4, 5/4, 6/4, 8/4 and 10/4. |
| whalersman |
Larry, I still have the photos but haven't scanned them as yet.. =___= They look something like the above but upside down.. The solid piece across the top is 12/4 (3" thick) and each piece at the end is 12/4 (3" thick). If anyone would like photos, just let me know and I will scan them... Joe Kriz |
| Tom W Clark |
Here's one view of Larry's teak risers: |
| whalersman |
Atta Boy Tom, And who said you weren't an Internet or Computer Geek.... Those legs appear to be made with 3 separate pieces of 8/4 teak to give it a 6 inch rise? After looking at the photos Larry sent me, that seems to be the case.. I was wrong in my description above.. I looked at it from a different angle in my head.. lhg, Joe Kriz |
| Tom W Clark |
Joe, You may have got the geek part right, at least. I don't know about the computer part... The photos of Larry's risers are from his Outrage 25. I have quite a collection of good photos Larry has sent me over the years. His risers are made from three levels of teak, as Joe points out. One could do this with solid stock too. You just need a good lumber source. Seattle is a good place for wood sources, especially if one is in the business of woodworking ;-) |
| Slippery Eel |
lhg, Thanks for the description. That clears up some thoughts I had. I'm glad to hear that they are rock solid without extending the length of the deck level risers. I will be building a similar set up on my montauk this winter. I have just received my new rps seat and rps pad from Halls. What a nice job they did. |
| whalerajm |
Larry, I curious as to why you designed RPS Risers as blocks under the "feet" of the RPS as opposed to making risers contoured to the dog-bone shape of the base. I realize only the feet make contact with the deck, so the full bone is really not necessary...Was it for engineering reasons, the cost of the teak, or "good looks" ? I guess you would also need 7 inch #14 SS screws to go thru 6 inches of riser...they might be next to impossible to find. |
| lhg |
Thanks for posting the photo Tom. Yes, since that picture was taken, the teak has been completely re-sanded, teak color stained, and varnished 10 coats. Currently, they look fabulous. Incidentally, the two screw holes in the boat floor, behind each block, are from some Dealership rigger, when boat was brand new. Knowing I was going to raise the seat, I ordered the boat with RPS NOT installed, which the factory accomodated. When it arrived at the dealership, some guy took the liberty to install it for me, and too far back, unknown to me of course! No wonder they went out of business 6 months later! Whalerajm - I designed the riser configuration as I did because I knew it wasn't necessary to have such a massive solid block of teak under the seat. The seat leg is really only held in place by the two screws at each end, so the teak blocks only had to be large enough to furnish necessary stability. The concept of building a "bridge" rather than a solid "causeway" made some sense to me. It keeps the boat non-skid floor more open, and is less of a water/dirt collection situation for the blocks. I thought tracing the dogbone shape in 6" solid thickness also made little sense design wise. For a 1 or 2" thickness it might look good, but not at this height. Nor would it be as stable. Regarding screw lengths, note in above post that I used 2" size into the plywood floor of the gas tank cover. This provides a MUCH more stable connection, besides practical availability. The compression pressure exerted by the screw head in the block is now down low, close to the boat floor. They are counterbored in from the top. To use a 5" long screw, even if I could find them, would be a mistake. When I initially raised the console on this boat 4", I DID use solid teak blocking, about 30" x 3" wide, 4" high. The shop that did them for me used three layers to accomplish this. I never liked the detail, and later changed these to the "bridge" design also. Much better looking, and just as sturdy, making boat floor easier to clean, etc. |
| lhg |
Joe - I just took another look at the photo. You sure are right, the teak gunwale looks terrible. The boat had just come back from a winter in Florida, where the sun/salt/humidity climate trashes oiled teak so fast you wouldn't believe it. Yes, shortly after the photo was taken, I varnished all teak on the boat. You should see it now! I also noticed the difference in oiled vs varnished teak in the bow pulpit picture posted in another recent thread. I'm so used to looking at the varnished pulpit now, that the oil treatment doesn't look so good. You see, I'm striving to make my Outrage look like a Hinckley! |
| Barry |
My RPS is raised using stainless steel risers. members.aol.com/bburtensha/outrage/rps1.jpg members.aol.com/bburtensha/outrage/rps2.jpg |
| JayR |
This being such a popular project, it is a wonder BW has not raised the seat to acccomidate the larger tanks. |
