posted 03-08-2004 02:25 PM ET (US)
Bert,Interesting that you asked this, because I just replaced the drain tube on my 1974 Katama on Saturday.
First, after reading the littany of archives on drain tubes (brass vs. PVC), (5200 vs. 4200 vs. o rings), I went with brass and 5200.
By the way, for those who argue that 4200 is less permanent than 5200 and thus a better choice, I offer this info: I am 44 and the boat is 30. The first drain tube lasted 30 and, if I installed it correctly, it should last another 30 years. I certainly do not plan on replacing this particular drain tube as a 74-year old!
Second, I spoke to ALAFIARAT, a member of this forum, on Sunday. Dave has a Newport that, I believe, like yours is a 1977 model. He says that his brass drain tube that starts in the sump does not penetrate the transom. If he sticks his finger in the hole from the stern, he feels smooth fiberglass, in contrast to mine, when the tube was removed, felt like foam. He spoke to Sue at Twin Cities Marine, who in turn spoke to BW who confirmed that the drain tube did not go all the way through the hull on at least that particular model and year.
You can reach alafiarat very easily through the search mechanism.
PF, I think the merits of having an external drain plug to prevent saltwater corrosion is miniscule and overshadowed by the drawback of not being able to plane out and remove any water inside. If you read LHG's near-tragedy, one of the things that allowed him to escape, was the ability to plane out.
Just my dos centavos worth.
Richard
