posted 03-11-2004 08:54 PM ET (US)
Hale,It depends on what model you have and what year it is, but chances are that the rail is one piece. Whaler would slide the Tees on the tubing and then bend it.
In some cases, like with the very long wrap around bow rail on the Super Sport models, the rail will be joined under an intermediate Tee.
These joints have what is called a Hot Dog in them which is a 4" long piece of 3/4" tubing that serves as a spline between the two rail segments.
If you have a rail that you want to replace or re-chrome the Tees on you can always remove the set screws, slide the Tee down the rail a ways and cut the rail to remove the Tee.
A Hot Dog can then be used to reconnect the rail. This apparently works better than you might think. It is reported that there is no loss of rail stiffness doing this.
This could also be a solution for rail tees that have set screws that no longer hold. The Hot Dog is tapped for the set screw so that provides additional grip.
