| Author | Topic: Through bolted transom |
| flyfisher1771 |
I have a 1967 13' that I am stripping to paint and at some point someone added 2 bolts that run from the transom to the engine compartment wall. It looks like they were trying to support the transom. Was this common? There was some transom damage that I can see now that I have stripped the paint. Any stories of transoms coming off these old Whalers? I know it sound corny, but some obviously did something to this one. Thanks |
In those early pre-1971 13-foot hulls there was stern bulkhead that ran straight across the rear of the boat, forming the engine splash well dam as well as adding some structural support to the rear. I don't recall anyone describing what you've got, which is apparently an attempt by a previous owner to bolt the transom to this bulkhead. See Cetacea Page 56 for an example of a nicely restored 13-foot hull with a modern engine adapted to it. http://continuouswave.com/whaler/cetacea/cetaceaPage56.html It might be prudent to check the transom for strength. Most of the transom strength comes from the embedded plywood. If that is rotted you won't have much structure in the transom. If the wood is gone, you can fill the transom with some material that can fill in the missing wood. I''ll be darned if I can think of the name of it. But it is a plastic product you can pour into the void where the wood used to be and it will harden and provide some structure. Maybe someone can join in with other ideas. |
| dscew |
Maybe I'm crazy, but I think I read somewhere on this forum that it's called "Liquid Transom." Or is that too obvious? |
| AC |
You can use pourable "Seacast" to replace rotted transom wood. "Seacast is a high strength casting compound combining reinforcements and additives in a polyester matrix." It supposedly has triple the strength of marine plywood. Absorbs no water and will not rot. Can be pre-fabricated and installed like plywood; or poured in place. www.transomrepair.com - e-mail: seacast1@netscape.net |
