posted 05-17-2004 03:58 PM ET (US)
After pulling twin seadrives off my 22 Revenge, there are a couple big holes on each side of the trasom (all the way through) where the engines were. Two of the holes (5" round) are above the water line and will not have to bear any load. The other two which are rectangular (7"Wx 5"H) are directly below the round ones and will be right where the new trasom engine bracket will be bolted on (48" wide).Assuming the repair of the outside would follow "Repairing Hull Damage the Whaler Way", what is the best way to plug the inside? If holes need to be drilled through the repaired areas, how do you make them strong?
What if I just cut a piece of marine ply ot fit the holes, glass the inside and outside, and then if the bracket requires holes drilled where the repair is, put a metal plate, inside, larger than the original hole and bolt through. This way the load would be spread beyond the parameter of the old hole? The bracke will require bolts/holes for mounting every 4-6" or so.
Any help greatly appreciated.
Bill
