  Stern Lamp Pole Frozen in Base
Author Topic:   Stern Lamp Pole Frozen in Base
Phil Tyson posted 06-02-2004 01:45 PM ET (US)   Profile for Phil Tyson   Send Email to Phil Tyson
While taking pictures of the dri deck install to post for ya'll, I noticed to my dismay that my stern light has broken right at the top of the upper bracket. Just one more thing...
I have seen the threads on the replacement poles and the wiring challenges. Think I understand that part.
What are the tried and proven techniques for getting the remaining pole out of the brackets. Mine is really stuck in both brackets. (bought the 86 Montauk in March)
Photo is on my page..Look at Stern Light album..
http://f2.pg.photos.yahoo.com/philtyson2002
I ask since, my brother's 13 has the exact same problem and we were unsucessful to date.
Thanks again.
Moe posted 06-02-2004 01:51 PM ET (US)     Profile for Moe  Send Email to Moe
Phil, the best penetrating oil I've found so far is PB Blaster, available at automotive parts stores.
If it appears that considerable hammering and/or prying and/or twisting is still going to be required, I'd remove the mounts from the fiberglas to keep it from suffering damage.
Moe
Backlash posted 06-02-2004 02:21 PM ET (US)     Profile for Backlash  Send Email to Backlash
Phil,
I agree with Moe on the PB Blaster, but if the stuck pole piece is corroded, Corrosion Block may work better as it will dissolve the corrosion.
Steve
jwgreene74 posted 06-02-2004 02:22 PM ET (US)     Profile for jwgreene74  Send Email to jwgreene74
Phil,
I ran into the exact same problem with the stern light from my 13'. The bigger bracket with the threads seemed like it was glued or bonded onto the actual light pole to hold it in place. I tried hammering, WD-40, naval jelly, prying - and none of them even budged the thing. I ended up prying through the aluminum pole around the top and bottom of the bracket, which still held fast to the pole and led me to believe that some kind of bonding agent was used in that area. This was a major bummer, especially since I had already bought a new stern light and pole and was ready to install it. I returned it to West Marine and ended up going with a portable stern light instead. 4 AA batteries and a heavy duty suction cup to keep it in place, and when I'm done I take it off and stow in a dry bag to keep it clean. Problem solved for $25 - and no wiring or new switch headaches.
Phil Tyson posted 06-02-2004 02:28 PM ET (US)     Profile for Phil Tyson  Send Email to Phil Tyson
There is this whitish gunk, kind of gritty around the threads of the top bracket.
daverdla posted 06-02-2004 03:06 PM ET (US)     Profile for daverdla  Send Email to daverdla
Phil,
I'd take both brackets off the boat. Cut the old pole between the brackets so you can deal with each brackets separately. Try clamping each bracket in a vise and see if you can break the pole loose with a pipe wrench after letting them soak with some of the previously recommended lubricants. You may be able to drive the old pole out. You'll probably destroy what's left of the pole but you can't reuse that part anyway. You may want to try heating the bracket - another good reason to take them off the boat. Be careful, those lubricants are extremely flamable. Take your time and you'll get them apart. I developed some strange way of dismantling corroded parts working on old british sports cars. What ever you do, don't mangle the brackets, they're expensive.
You could also take the brackets to a machine shop and have them do it. They can run a reamer through to clean up the inside of the brackets after they're done. I don't think it cost would very much.
Dave
ShrimpBurrito posted 06-02-2004 03:23 PM ET (US)     Profile for ShrimpBurrito  Send Email to ShrimpBurrito
Phil - I was in your exact same situation last year. We won't get into the specifics of how the light mast broke, but it did involve a shelving unit full of garage stuff (you know, like chemicals) to come crashing down.
I seriously doubt any of the solvents described above will help you. I tried everything. That white stuff you described is aluminum oxide, and it has some SERIOUS binding power. Some people (like me) also experience this power when they try to open up their engine control box at the helm.
I did some research into what would react with aluminum oxide to break it free, and it turns out that the active ingredient in Miracle Grow would do the trick. I can't think of the name of it (magnesium something?), but it really doesn't matter because it isn't nearly concentrated enough to do the trick.
I ended up taking a bare hack saw blade and cutting the piece of the mast that is inside those brackets. Of course, you do this from the inside. Be careful to stop once you go through the mast so you don't continue to cut the bracket. Make 2 cuts opposite each other, and the pieces should then come out much easier. Wedge a screw driver in there to separate part of it, and then use a pair of needle nose pliers to curl the rest of it out. Then sand down the inside of those brackets.
To avoid this happening in the future, just remove your light every so often. Every time is best.
ShrimpBurrito posted 06-02-2004 06:32 PM ET (US)     Profile for ShrimpBurrito  Send Email to ShrimpBurrito
By the way, you can reuse your light mast, but it now be about 6 inches shorter.
jimh posted 06-02-2004 08:11 PM ET (US)     Profile for jimh  Send Email to jimh
The "light" is what is seen by someone. The "lamp" is what makes the light. The "bulb" is what is in the lamp that makes the light.
Chuck Tribolet posted 06-02-2004 08:23 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Rather than clamping the brackets in a vise, I'd find a piece
of pipe with an ID just greater than the mast. Put the mast
in the pipe and tap on the mast.
Phil Tyson posted 06-02-2004 09:19 PM ET (US)     Profile for Phil Tyson  Send Email to Phil Tyson
Wow! Some really good advice. I am glad I waited and posted.
I think I will try Chuck's suggestion first then go to Shrimp's.
Thanks to Dave and Moe for reminding me to take the brackets OFF THE BOAT.
Thanks to Backlash too!
Jim - you crack me up !!! too funny.
Since it is forecasted to rain this week (and all last week) I will wait to take off the brackets. Duck tape for now.
ShrimpBurrito posted 06-02-2004 09:40 PM ET (US)     Profile for ShrimpBurrito  Send Email to ShrimpBurrito
With my writing improving so much as a result of learning things like the difference of light vs. lamp, I'm soon going to find myself an agent.
simonmeridew posted 06-02-2004 10:53 PM ET (US)     Profile for simonmeridew  Send Email to simonmeridew
Phil:
Unless the tube was welded to the bracket(very unlikely and anyway almost impossible):
Echo taking off the brackets from the boat.
Echo sawing off below and above the brackets
Get a dremel tool with a bit(bur) and carefully cut a groove inside the offending tube. Take your time so you don't cut the bracket, which looks at least on my boat to be cast and therefore FRAGILE and not malleable. Then carefully collapse the tube with a screwdriver and needlenose pliers. Work the tube out, and polish the ID of the bracket so that the new tube will slide in easily.
Don't agree about reusing the shorter tube: it's supposed to be a specific minimal distance above the red/green light; I think: 1 meter. If it's shorter it technically isn't right.
simonmeridew
Tom W Clark posted 06-02-2004 11:10 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Phil,
If you have aluminum oxide, you do NOT have a Whaler OEM stern light. Your 1986 Montauk should have a stern light mast made of stainless steel tubing, If it were an older model the mast would be chrome plated brass.
Either way, the corrosion problem you report is very common. I strongly suggest you try using Aero Kroil penetrating oil as a first attempt at freeing things up. It may not be magical but it is superior to all other penetrating oils in my experience.
Regarding the breaking of the mast in the first place, I must confess that I have been there and I have done that...multiple times with my Striper 15 and the garage it got backed into for a period of time. Yup, the light got shorter and shorter.
All you need is a tubing cutter to produce a clean cut. If you do have the stainless steel mast type will need a very high quality tubing cutter to cut it. If it is aluminum or brass, any old hardware store tubing cutter will work fine.
Regarding the adherence to current International and Inland boating rules and the height of the stern light, the current requirement is one meter above the port and starboard running lights. Montauk stern lights were not built to this height (54") until the mid 1980s.
Does anybody know if (strictly speaking) one is obliged to retrofit an older boat to meet current requirements in terms of navigation lights? Or is it merely a manufacturer's requirement?
I mean, for example, a Ford Pinto is perfectly legal to drive today even though it does not have air bags and a third brake light.
Joe Kriz posted 06-02-2004 11:22 PM ET (US)     Profile for Joe Kriz  Send Email to Joe Kriz
That is great Tom.
Ford Pinto
Are there any still around that haven't exploded?
Legobusier posted 06-02-2004 11:24 PM ET (US)     Profile for Legobusier  Send Email to Legobusier
Tom,
I believe your assumption is correct regarding the retrofit requirement for older boats - there is none assuming the boat is "original". However, I would not be surprised if technically you would be obligated to "come up to current standards" if doing a replacment/modification of a significant nature. This "grandfather clause" is pretty typical in most automotive and even building code requirements as I'm sure you're aware.
As a matter of fact, I have an original 1948 Willy's CJ2A that I took to get a State inspection here in VA (required every year). Well, the old dude doing the inspection proceeded to argue with me that I was required to have seatbelts in the Jeep. Give me a break - it's a friggin antique and seatbelts weren't even manditory until (I believe) 1968. I argued with him for a while and finally he gave in but just for spite failed my inspection since I didn't have my doors/top on - making up some excuse about them being required if they were part of the original. What a prick. I was sick of arguing, so I had to drive home, put on the doors/top and return to the garage to pick up my sticker. Needless to say I don't go back to that shop anymore.
I still have the Willys. It probably has 30K original miles or so on it and is in real good mechanical shape. Needs a lot of cosmetic work and it's not real happy there's a Whaler in it's place in the garage now. :O
Chris
Legobusier posted 06-03-2004 08:55 AM ET (US)     Profile for Legobusier  Send Email to Legobusier
I've used this method countless times to remove things of this nature. One of the best "pipes" I've found to use is a socket set - especially if you have deep well sockets. They come in just about every size and are basically indestructible with nice eased edges. I've also used these to push on bearings and stuff. Works like a champ.
Chris
Chuck Tribolet posted 06-03-2004 11:23 AM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Good idea about the sockets. And could use a smaller one
to push the tube through.
BTW, Lego, I wonder how many folks here "get" your handle?
(I do, I thought about being an architect at one time).
Legobusier posted 06-03-2004 12:15 PM ET (US)     Profile for Legobusier  Send Email to Legobusier
Probably not many Chuck, but who knows - there's quite a few architect types around here and even more of the smarter ones who "thought about it" but decided to do something else.
Most probably all think I'm some French pacifist or something :).
(The "Gobo" part comes from Fraggle Rock - an old Jim Henson muppet show - for some reason I picked up that nickname in high school. I think it had something to do with the hair)
Here's a picture:
http://www.covingtonhendrix.com/bio.html
You have to "mouse over" my name to see it.
DOH...just realized I haven't updated the kid count...we're up to 3 now. Better hope my wife doesn't see that :)
Chris
Chuck Tribolet posted 06-03-2004 03:46 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Actually I had it as a play on Lego (the kid bricks) and
the other architectural part that we'll let everybody guess
at for a while. ;-)
Legobusier posted 06-03-2004 04:38 PM ET (US)     Profile for Legobusier  Send Email to Legobusier
So you and jim had the same idea...interesting. When people tell me they "get it"....I wonder if they do....or if I do for that matter?
jimh posted 06-03-2004 08:21 PM ET (US)     Profile for jimh  Send Email to jimh
I have a tall pole that elevates the white all-around stern light fixture so that it is one meter higher than the reb/green side lights. As far as I know this device is the original one that came with the boat in 1987.
Due to its light weight I always thought it was aluminum. It appears to not be magnetic. There is no sign of any rust. It is finished with a dull satin natural finish, typical of burnished aluminum.
How could I deduce its metalurgy more accurately?
Tom W Clark posted 06-03-2004 09:43 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Jim,
By your description I can tell you you have an anodized aluminum pole which was typical of the 18 foot and up Whalers in the mid 1980s. By the late 1980s even these larger (1.25" diameter) masts were being made of stainless steel.
But this thread is about the 3/4" diameter light poles used in the 16' 7" and smaller classic Whalers and the unique mounts that hold the pole in place.
jimh posted 06-03-2004 09:59 PM ET (US)     Profile for jimh  Send Email to jimh
I think the change to a steel construction was a good move. There is an unavoidable tendency to want to use this light pole as a lever for moving the boat, particularly if one is at a dock and is stepping aboard. The tensile strength of aluminum was not up to this task and as a result there is a slight bend in my light pole, probably induced when the force required to move the boat was greater than the tensile strength of 6061T6 aluminum alloy in 1.25-inch 0,058 wall tubing.
Legobusier posted 06-03-2004 10:06 PM ET (US)     Profile for Legobusier  Send Email to Legobusier
Tom, this one's right up your alley.
I noticed Phil's lamp (1986 Montauk) is a sort of a "Jelly Jar" looking fixture. Here's a good picture of it:
http://f2.pg.photos.yahoo.com/ph/philtyson2002/detail?.dir=/2c53&.dnm=4b3f.jpg
Mine (1987 Montauk) look nothing like that - but more of a cheap (oxidized) plastic:
http://www.covingtonhendrix.com/Montauk_II/
(the picture third from the end shows it best)
Which one is original? Phil's looks much nicer and more heavy-duty. Mine is pretty crummy and I'd like to replace it - especially if I don't have the original part.
Thanks,
Chris
Phil Tyson posted 06-04-2004 12:16 AM ET (US)     Profile for Phil Tyson  Send Email to Phil Tyson
My lens is new. I took the old one off one day in March and when I got back from the ramp at the end of the day I noticed it missing. Must have put it on the swim platform and it fell off in transit.
Think it was a Perko replacement at boatersworld.
Tom W Clark posted 06-04-2004 12:27 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Chris,
What you have is not original. It is a cheapo universal replacement. Phil's is original.
That lens is what is called a fresnel lens. These replacement lens are readily available at most places like West Marine and Boater's World.
http://perko.com/cgi-bin/perko.pl?dis+248-spare_lenses_info
15ftlover posted 06-04-2004 10:14 PM ET (US)     Profile for 15ftlover  Send Email to 15ftlover
Jimh,
I believe the term shear force might better describe the bend in your pole (no pun intended I am referring to your boston whaler lamp column;). I believe tensile strength is a parameter used to describe the force at which the metal gives way to forces applied in tension, ie. vector of force parallel with long axis of a rod/wire/pole. Not sure I am right but my structural engineer father was always willing to provide instructive feedback after I "sheared" some peice of equipment off of our boat growing up.
jstachowiak posted 06-04-2004 10:19 PM ET (US)     Profile for jstachowiak  Send Email to jstachowiak
You can't get yours out, I can't get mine in.
Good ideas, PB blaster to break the screw thingy that appears to be preventing my pole from being inserted. I hate when that happens.
Bill4169 posted 06-05-2004 08:06 AM ET (US)     Profile for Bill4169  Send Email to Bill4169
Legobusier where did you get that mat that is on the deck of your boat?? Its in the first picture with the light. I would like to buy one.
Legobusier posted 06-05-2004 08:33 AM ET (US)     Profile for Legobusier  Send Email to Legobusier
Bill, I think you must be referring to Phil's boat not mine. He put Dri Deck on his boat just recently:
http://continuouswave.com/ubb/Forum3/HTML/006341.html
Bill4169 posted 06-05-2004 09:33 AM ET (US)     Profile for Bill4169  Send Email to Bill4169
Yes it was his boat.......it looks good
jimh posted 06-05-2004 08:13 PM ET (US)     Profile for jimh  Send Email to jimh
15ftlover—When a tubing section is bent, it is the tensile strength of the material that is the determining factor. I have designed and built many tubular aluminum structures (large Yagi antennas), and I have analyzed them for potential bending (in winds up to 96-MPH). It you grab the end of a pole and pull, the material tensile strength is what is being stressed.
Aluminum tubing in 6061-T6 alloy is typically used. This has a tensile strength of about 45,000 PSI. Some other alloys have higher tensile strength, but cost more. (7475-T761 = 75,000 PSI)) These are often called "aircraft alloys".
Prior to becoming a trailer-boater, I used to have quite a bit of aluminum up in the air in the form of Yagi antennas. Amateur radio callsign K8SS. First licensed 40 years ago at age 13. Never had one fail due to wind loading.
For more information on material properties see:
http://www.matweb.com/
Phil Tyson posted 07-22-2004 08:52 AM ET (US)     Profile for Phil Tyson  Send Email to Phil Tyson
UPDATE -
I managed to back out the screws and removed the bases from the transom. The prior install was well done with caulk in the screw holes and a bit more around the base. It took some persuasion. For a minute or two, I was thinking "this does not want to come off.."
I cut the pole in between the brackets drilled a 3/4 hole a bit large through a thick piece of wood so the pole slides all the way through and the base sits on the board. Took a couple wacks at the bottom part, no go. The board split. The top part looks more frozen.
They are soaking in PB Blaster/penetrating oil. Think I may use the hack saw and cut the inside.
hooter posted 07-23-2004 12:49 PM ET (US)     Profile for hooter
It sounds like several posters here have had problems with aluminum poles gettin' stuck in their OEM stern light brackets. In Whaler hulls before 1991 and smaller than the Outrage 18', those upper and lower brackets are nickel plated bronze. Ah believe they are stainless steel on hulls after about 1991. Read up on galvanic corrosion here: http://www.corrosion-doctors.org/Aircraft/galvdefi.htm to understand why you is havin' this problem.
Once you do get your self-welded aluminum pole out o' those bronze brackets, correctin' this problem isn't difficult or cheap. Just forget about usin' those inexpensive ready-made aluminum light poles. You made that decision back when you bought the Whaler. Here are two options: you can pay Boston Whaler an arm and a leg for their plated brass stern light pole, or for consid'rably less (just either appendage, not both) you can manufacture one your self. Here is what Ah did in one o' mah more anal retentive younger phases with a Montauk stern light. Buy you a piece of brass pipe sized to match the original light pole, either 1/2" or 5/8" o.d., Ah cain't remember. Buy it nice and long, like 36 inches or so. The new Montauk stern lights look to be mebbe 40" or longer. This makes your light visible from all around the boat when you're underway in fog or at night, a good thing and better than the stubby OEM pole Whaler used in the 1980's and before. Usin' a conduit bender, put a li'l bend of about 15 degrees about four inches from one end to make the "top" that'll enter the light fixture. Eye-ballin' it in the pole brackets, now bend the top end o' the pipe to "vertical", 90 degrees to the boat deck surface. Once you're happy with the bend, take that pole to a re-plater to be nickel plated. The pipe and plating, as Ah recall, cost me about $75.00, a lot for li'l piece of shiny pipe, but a good bit less than what mah helpful parts lady needed to charge for the same piece. You'll find a Perko all-around light to match the look of your OEM fixture if needed. Just run your leads down through the pole, pop a cork in the bottom end, if you like, hook her up and go boatin'. Take the missus, some sparklin' wine and some table linen out for an evenin' cruise with your new stern light shinin' brightly. Who knows? You might get lucky:-!
Legobusier posted 07-23-2004 02:12 PM ET (US)     Profile for Legobusier  Send Email to Legobusier
Hooter,
Perhaps I'm missing the obvious here, but why not just buy a piece of stanless tube and accomplish the same thing vs buying brass & then having it plated?
Chris.
hooter posted 07-23-2004 02:42 PM ET (US)     Profile for hooter
If you replace the mounting brackets with stainless steel, too, you're in bid'ness. Otherwise, SS on bronze doused with salt water will still set up a li'l science project model of a batt'ry right there on your boat stern, resultin' in galvanic corrosion. Read some more: http://www.mcnallyinstitute.com/04-html/4-1.html This corrosion will not be as rapid as with the aluminum, mind you, but it can still be a problem.
Phil Tyson posted 07-25-2004 05:04 PM ET (US)     Profile for Phil Tyson  Send Email to Phil Tyson
UPDATE =
Well, after 2 more hours of effort, got the pieces out. Man were they REALLY stuck.
I have replaced the pole with a Perko replacement (with the bend and bare wires).
Will periodically change its height and keep an eye on it.
Thanks for all the help.
whalernut posted 07-25-2004 07:12 PM ET (US)     Profile for whalernut  Send Email to whalernut
Phil, good news!! Can you tell me which make and model of light that is you bought with the exposed wires? Thanks-Jack.
Phil Tyson posted 07-25-2004 09:21 PM ET (US)     Profile for Phil Tyson  Send Email to Phil Tyson
It is Perko PKO 1311 DP 3CHR. I finally found it at a local marine store that also does internet sales (good prices)
http://store.hamiltonmarine.com/browse.cfm/4,7628.html
The photo does not show the wires but they are coming out of the tube. It comes with a base that I am not using.
The new light is alot taller than what I replaced. Think it was approximately 12 inches tall. The new one is 30 inches.I am not sure the old one was correct.
Will post a photo of it installed tomorrow on my yahoo photo site.
hooter posted 07-26-2004 01:27 PM ET (US)     Profile for hooter
Seems a super-thin application of marine grease on that aluminum light pole would do the trick, just on the part that's in contact with both o' the bronze or stainless brackets. Might be worth a try. Shoot, even Vazaline would be better'n nothin'. Just keep those two metals separated:-!
gansett posted 07-26-2004 06:34 PM ET (US)     Profile for gansett  Send Email to gansett
If the "light" is what is seen by someone and the "lamp" is what makes the light, what do I call my bow light when it is not illuminated? ;-)
"Light" may also be used a "source of light"... such as a lamp.
My stern thingy is also frozen in the base.
whalernut posted 07-26-2004 06:42 PM ET (US)     Profile for whalernut  Send Email to whalernut
Thank you Phil :-) Jack.
Phil Tyson posted 08-02-2004 02:24 PM ET (US)     Profile for Phil Tyson  Send Email to Phil Tyson
Before and after photos...
click on Stern Light Album
