  Transom Green Line Repair
Author Topic:   Transom Green Line Repair
71whaler posted 08-04-2004 11:22 AM ET (US)   Profile for 71whaler   Send Email to 71whaler
[This article began with a discussion of a problem with the operation of the forum software (now deleted). Please post questions or comments about the forum and its software to the META-Forum. It is not particularly effective to include anecdotal reports of software problems with articles in other forums--jimh.]
I have a 1971 Whaler 16-foot hull which I recently purchased. For the most part the hull is in great shape except for some delamination along the top of the transom. The previous owner tried to seal this with some kind of glue or other yellow substance. On either side of the transom it has delaminated aprox. 1" wide and maybe 1" down. When you look down on it you can see the glass fibers. I would like to repair this using the West System epoxy but I am not sure on the procedure. I did a search of the site but could not find any detailed procedure for transom repair. Before applying the epoxy should I sand the area and try and rmove some of the fibers so the epoxy sets right. This is my first boat and first use of epoxy so any help would be appreciated.
Thanks.
gansett posted 08-04-2004 02:12 PM ET (US)     Profile for gansett  Send Email to gansett
There is a seam, 1/4" or so, along the top of the transom where the blue interior meets the white hull. Are you saying that this seam (greenline) split on each side of the motor well... and opened up 1" wide? Or do you mean the glass has delaminated from the transom. If its the first, I have fixed two boat with this problem
I haven't seen one that wide, but have repaired one that was half as wide. I used a long, narrow drill bit to remove as much material as possible from inside the gap. I used a vacume cleaner to suck out the shavings. I then used clamps to close the gap. I put two thicknesses of 8 oz fiberglass weave in the gap, and used a syringe to fill the gap with resin, then clamped it closed. I chose not to use West because I thought the repair line might be less visible if I used "original" materials.
Be sure you have solved any other water infiltration problems in the transom. If you close the gap, but then take on water, the wood will expand and the gap will re-open.
Legobusier posted 08-04-2004 02:28 PM ET (US)     Profile for Legobusier  Send Email to Legobusier
gansett, what type of resin did you use - anything special?
I too have this problem. Mine has been repaired but doesn't look great so I was thinking of grinding it out and doing it again.
Thanks,
Chris
gansett posted 08-04-2004 02:47 PM ET (US)     Profile for gansett  Send Email to gansett
Polyester resin. I'm sure epoxy would bond well, I don't know if it would "show" a new seam.
71whaler posted 08-04-2004 04:58 PM ET (US)     Profile for 71whaler  Send Email to 71whaler
Let me take a closer look at the transom and report back, but I think it is along the seam. I may try and post a picture if I can figure out how to do it. Thanks for the help.
jimh posted 08-05-2004 08:53 AM ET (US)     Profile for jimh  Send Email to jimh
The "green line" seam at the top outer edge of the joint between the hull and the liner should not be open or split. If the gap is 1-inch wide that sounds like a rather severe problem.
If the repair appears yellow, it could be old epoxy. Epoxy tends to yellow with age and exposure to UV radiation. Epoxy will be very hard, and not at all pliable.
One possible cause for this kind of gap is internal pressure forcing the laminates apart. This could have been caused by swelling in the imbedded wood caused by intake of water.
You should check the transom carefully to see if there is water in it.
If the gap has occurred just from abrasion and the transom does not have water, it will be an easy repair to re-seal that joint.
You can make repairs with either polyester resins or epoxy. My preference is to use epoxy because of its better bonding strength. You must be careful not to use large amounts of epoxy to fill voids because of the tendency for thermal run away. The cure of epoxy is an exothermic reaction, and much heat will be produced from large volumes of epoxy sitting in a hull void.
gansett posted 08-05-2004 09:20 AM ET (US)     Profile for gansett  Send Email to gansett
Peter, here is a picture of a blown-out greenline seam. Is this what you are seeing on your boat? http://www.kinnakeetadventures.com/DSC00076.JPG
71whaler posted 08-05-2004 09:42 AM ET (US)     Profile for 71whaler  Send Email to 71whaler
Yes that is it. On mine, the split is not as long left to right, only a few inches but like I said before it is rather wide. The boat was previously owned by a friend whose father owned it before him and he can remember it being there for a long time and they would just slap sealent, his words, on it from time to time. What is the best way to check the transom for water? Over the weekend I will get some pictures of the problem to post.
Thanks for your help.
71whaler posted 08-08-2004 04:57 PM ET (US)     Profile for 71whaler  Send Email to 71whaler
OK. I took some pictures of the transom delamination and some of my new boat. Let me know what you think. The delamination was not as wide as I orginally posted, the starboard side was aprox. 1/2 inch and the port side much less. I added a tape measure for scale. I have also included some pictures of the gel coat damage on my keel and a spot in the bow by the anchor locker.
I bought the boat for $1200 including trailer, GPS, depthfinder and VHF radio. The motor needed about $1800 worth of work.
Here is the link to the pictures let me know if it works.
[url]http://pg.photos.yahoo.com/ph/pwbernhardt/album[url]
pete
PeteB88 posted 08-09-2004 11:05 AM ET (US)     Profile for PeteB88  Send Email to PeteB88
Looking at the photo sample of the transom delam I would probably do the following -
- Use WEST System products
- Be prepared to inject as much epoxy into the void as possible, saturating/covering the mating surfaces as completely as possible
- clamp w/ one or more bar clamps using boards to distribute the clamping pressure as much as possible.
- Use care when clamping that you do NOT use too much pressure - epoxy doesn't require lots of pressure like other glues -
- take Jim's advice seriously about exothermic reaction - heat could damage foam.
But before I would do any of that I would email the images to WEST tech support and call them for advice. There are lots of marine epoxy but WEST/Gougeon customer and tech support is second to none which = = my loyalty for many years. If you ever get to Mich visit and tour the plant and thank them in person.
I would NOT use polyester resin.
good luck.
71whaler posted 08-09-2004 05:51 PM ET (US)     Profile for 71whaler  Send Email to 71whaler
Thanks for the help, PeteB88. I will take your advice and contact tech support with my pics and carefully research this before I begin. I'll try and post some follow up pictures when I am done.
71whaler posted 08-12-2004 02:57 PM ET (US)     Profile for 71whaler  Send Email to 71whaler
I don't know if that first link worked right or not because the Yahoo settings were wrong. If anyone is interested here is the corrected link.
http://pg.photos.yahoo.com/ph/pwbernhardt/album?.dir=/d6b0
Legobusier posted 08-12-2004 03:34 PM ET (US)     Profile for Legobusier  Send Email to Legobusier
Pete, I for one would be interested in the further reports of your repair as I have a similar situation, although not as severe. Please follow up with results or email me if you prefer.
Heck, I'll even come over and help you if you like - I see you're also in Virginia Beach. We can experiment on your boat and do what worked on mine :)
Chris. (ps. nice flounder. Is that at the 3rd Island?)
By the way, you almost had the url tags right, you need a [/url] at the end - without the slash, it won't work.
71whaler posted 08-15-2004 11:35 AM ET (US)     Profile for 71whaler  Send Email to 71whaler
Chris, I'll let you know how I make out and if I need a hand. The flatie was caught at the 1st Island.
