| Author | Topic: Replacement Miniature Electric Bulbs for Navigation Lights |
| wfcrawford |
Trying to buy a replacement bulb for my '84 Outrage bow navigation lights. There are no markings on the bulb (other than USA) but it's a dual contact, bayonet base. The bulb is the same size as a 1157 trailer bulb and has one filament. West Marine lists a half dozern DC-Bay bulbs but not sure which I need. Any help appreciated. Thanks. |
| Dick |
It is probably a #90. Dick |
| Joe Kriz |
Here is the link to the Perko #337 bayonet style bulbs. The #90 is listed as 7 Watt http://perko.com/cgi-bin/perko.pl?dis+337-spare_bulbs_for_util_light_info I would be interested in what the original bulb was also. Thanks for bringing this up. |
| Joe Kriz |
I went out to the garage and took both covers off my Bow Nav Lights. Both bulbs were #1152. I am not sure if these are original as I am the second owner of this Outrage 18. I did a little research on the bulbs. #1142 = 18.4 Watts, 1.44 Amps Can anyone else confirm what bulbs they have in their Bow Nav Lights? |
| jbarrow4124 |
My 83 Outrage uses a T1004 Bulb. |
| Joe Kriz |
jbarrow, Are you the original owner and know for a fact that these are original? |
| Joe Kriz |
I know that LHG is the original owner of an Outrage 18' and 25'. He also has 2 brand new, in the box, Wilcox Crittenden Bow Navigation Lights. LHG, |
| LHG |
Joe - I'll take a look for you. I do remember that I had to replace one of the lamps on my 18 Outrage, and that Lauderdale Marina wanted $7.50 for one. Then I found the same lamp in an auto store for about $1.50! I seem to remember it being a single contact lamp? I'll check the originals. Do you want some photos of my new spare ones, from the original box? |
| Joe Kriz |
LHG, I will take all the photos you can send me of the bulbs, boxes, lights, etc... Thanks |
| LHG |
Ok, Joe had it right with his 18. I checked my box of brand new fixtures, and 1152 is indeed the original lamp. The lamp also shows markings of 12V 21CP (candle power). |
| jbarrow4124 |
Joe Kriz, I'm not the original owner and I don't know if these are original. I am wondering though, how did you research the wattage and amps of the lamps? I would be interested in what a T1004 puts out. My bulbs are 10 years old and still working well. Both are dual contact with what appears to be a brass base.
Thanks, Jack |
| LHG |
Not interested in selling, but the lamp is a two contact base. |
| Joe Kriz |
jbarrow, (Jack) I puched in 1004 miniature bulbs in Google and came up with some info. I did this with the rest of the bulbs also. It took quite a bit of digging to find out all the info. Some sites had the Watts while others had just the Amps, etc. I did find out that the 1004 had .94 Amps. I never did find out the Watts on that bulb. Here is the chart from above with the 1004 added: #1004 = ??.? Watss, .94 Amps |
| wfcrawford |
Thanks for all the info re the lights. One more question. Looks like the 1152 is the original bulb but West Marine does not list that bulb. They do list the 1004 and 1042, both of which are dual contact, bayonet base. Will both these /fit/work, just with slightly different brightness (due to different watts rating) ?? If the answer is "no", where can I purchase the 1152 bulbs? Thanks. |
Chicago Miniature Lamp (CML) has a very comprehensive catalogue of miniature electric lamps and replacement bulbs: http://www.chml.com/electric/incan_01.cfm Some caution should be used when replacing the miniature electric lightbulb in your navigation light fixtures. The lenses in these lamps are typically made of plastic. If a bulb is used that has excessive wattage, it will generate too much heat which can damage the plastic lens, either discoloring it or possibly melting it. On the other hand, a proper replacement should be used to maintain the necessary light output. Navigation lighting that is too dim is not any good, either. I would not rely on the existing bulb for guidance; it may have been replaced with the incorrect bulb sometime previously. On quality navigation lanterns like those used on Boston Whaler boats, the manufacturer usually has some markings on the lamp fixture to indicate the proper replacement bulb type. |
| Joe Kriz |
wfcrawford, Here is one place but the price isn't cheap: http://www.topbulb.com/find/prod_list.asp?intSubCategory=506 I would try your local Auto Parts store. If they don't have it, maybe they can order it. I know mine are Brass on the bottom and I see some advertised as "Nickel Plated" over brass. --------- |
| LHG |
Mine also have silver color bases, so maybe they are the nickel coated version? |
| wwbach |
Don't know that anything was resolved in this thread but my 86' 18 Outrage had the 1152 bulb in it (at least on the port side one that was blown!). The local CarQuest and NAPA store don't carry these bulbs (not even in their warehouse) and looked at me sort of cross eyed. The NAPA guy was able to cross reference to an 1142 which I bought. I'll report back on how it works after the weekend. -- Bud |
| Buckda |
Bud - Make a run up to Wolf's in Benton Harbor. They carry the correct marinized bulb and are inexpensive (be sure to check ALL of the packages as they are quite often marked differently). |
| wwbach |
The 1142 bulb seems to work just fine. I only observed in daylight, but they are *supposed* to be brighter. -- Bud |
| 1982MONTAUK |
The eqaution for DC power (Watts) is Volts X Amps = Watts. |
