| Author | Topic: Pate Tanks Venting |
| Salty Tricks |
I was wondering ...how are Pate tanks suppose to be vented? |
| memorymaker |
Normally they are vented via the twist lock cap provided |
| Salty Tricks |
Thanks...I am wondering if this is the problem with why my engine doesn't fully power up. I push the choke and she definately has full power so I know I have a fuel problm somewhere. |
| David Jenkins |
Unscrew the cap from the Pate tank and shake the cap. If the cap does not rattle when you shake it, you need to call Pate for a replacement cap. |
| Chuck Tribolet |
If it's not venting, it will go WHOOSH when when you pull the cap after runnig a bit. And the Pate will be visibly pushed in a little before the engine notices. The choke would have to pull fuel through the same system. Another possibility is sucking air at the tank quick disconnect. Been there. You can check this by having someone
| Salty Tricks |
Well thanks for all the advice. I am just confused as why it is running well for several minutes and then bogs down. If I let it sit for awhile it will then repeat the pattern. this led me to believe it was the vent. Nonetheless I purchased a new disconnect and an inline filter (under cowling). I already installedd an external Water seperator /fuel filter previously. I will check my connections to make sure I didn't introduce an air leak. I will let you know what I find...again thanks for the help |
| Salty Tricks |
Well it's not a vent problem. Tested the boat and when she slowed down I loosened the cap. No difference, no pressure so I'm back to some other ideas you folks suggested. I am now thinking maybe a weak fuel pump but wouldn't this not allow the engine to initially run fine as it is doing? Also it appears rebuilding a fuel pump is no biggie,,is this the case? |
| bigjohn1 |
Something very simple that anyone can forget is to ensure the fuel line is not getting bent/crimped. While out this weekend, everytime I slowed down from planing speed to retrieve a fish, the engine started spitting and it was ready to die. Come to find out, my 12 gallon Tempo tank was sliding just a tad forward (under the rps) when I slowed down - this caused it to pinch the fuel line. Taking the tank out and re-installing with the fuel fitting facing aft rectified this. Make this easy check to rule it quickly out so you can continue on through the fuel system in a methodical fashion - good luck. |
| crabby |
A bad primer bulb and it's associated checkvalves can cause similar problems. Replace with genuine OMC/Bombardier parts (not tempo or sierra). |
| wbullwin |
Has anyone looked into what ethynol does to these Pate tanks? |
| ratherwhalering |
According to Pate, their tanks are suceptible to degredation from Ethanol. Pate explains that this may result in "fish scale" like residue in the tank, not liquified black sludge as reported here: http://www.boatus.com/seaworthy/fueltest.asp Pate believes that the liquified black sludge is a result of poor quality fiberglass resin and interior tank gel coating. Pate states that they used a high quality, low styrene content resin in the manufacture of their tanks. There is no interior lining, other than a laminate resin. Pate recommends inspecting the tank and aluminum screen on the pick-up tube regularly, in addition to installation of a quality in-line fuel filter. |
| megawhaler |
I'm willing to bet its the fuel pump! ie Diaphram. If you hold the key in....can you just drive along like there is nothing wrong?? If so, start with the fuel pump. Cheers, |
