  Outrage-18 Sea Drive conversion
Author Topic:   Outrage-18 Sea Drive conversion
ratherwhalering posted 05-11-2005 08:52 PM ET (US)   Profile for ratherwhalering   Send Email to ratherwhalering
Today was a milestone for the restoration my friend and I are undertaking. He purchased an Outrage 18 a few months ago, and we are replacing the Sea Drive with a jackplate and repowering with a c.1990 OMC 150/175 HP engine.
Today, we de-rigged the Sea Drive and dropped it off the transom. This was quite similar to a normal engine, with the exception of six mounting bolts, a transom rigging plate, and some thru-hull assemblies that we had to protect from damage while sliding the Sea Drive and engine off.
The next stop is the fiberglass shop, then the real fun begins. I'll keep updating the thread as we come closer to installation and the first sea trial!
--Rob--
LHG posted 05-11-2005 10:07 PM ET (US)     Profile for LHG
I did not have a chance to pull my 18 out of the garage and tilt up the engines, but from looking at the dimensions, I am quite convinced that a hydraulic lifting jackplate, like the T H Marine Hydro-Jacker in 10" setback will be required. So for the moment, at least, I would begin budgeting for that expense.
ratherwhalering posted 05-13-2005 02:57 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
Thanks for the reply, Larry. We have decided to go with the Slidemaster 12" manual jack plate. Price was the deciding factor, unfortunatly. I also investigated 12-inch Stainless Marine mini-brackets, but these do not offer the adjustability that a jack plate does. The plan is to mount the manual jack plate, find the ideal height adjustment using the jack plate's features, then decide whether to keep the jackplate as is, add a hydraulic unit, or replace with a mini-bracket. For the initial set up, and since this is sort of an experiment, we are selecting the lest expensive option that offers the most flexibility. The boat is out for glass right now, the bracket is on order, an engine deal is in the works, and with any luck, I will be posting pictures of the completed project taken at the NorCal event next weekend.
ratherwhalering posted 05-13-2005 03:37 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
I just spoke with Chuck Bennett at Boston Whaler, and he gave the thumbs up for mounting the jackplate through the transom insert, if needed. Apparently there was quite a bit of reinforcement added to accomodate the sea drive, and this should not be an issue.
ratherwhalering posted 05-13-2005 03:38 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
problem... ;-)
LHG posted 05-13-2005 03:55 PM ET (US)     Profile for LHG
I still say that if you mount the jackplate higher than the standard cut transom, you're going to have an engine running too high, with no ability to drop it down.
Can you add hydraulics to a manual Slidemaster as a retrofit?
ratherwhalering posted 05-13-2005 04:56 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
Larry, I understand what you are saying, but I how high are your 115s on the 10-inch Springfield jack plates? I think an additional 3.5-inches of lift isn't out of the question, especially with the 12-inch set back and addition of a performance propeller. Instead of raising the jack plate's adjustment 3.5 inches, I am proposing raising the jack plate itself a modest 2.5-inches, and then using the jack plate's adjustment/engine bracket's adjustment to raise it an additional 1-2 inches as needed. We have that option because of the transom insert. Of course this contemplates your sugguestion of a side mounted steering cylinder so that the lowest engine-mounting-to-jackplate setting can be used. On a side note, I am not married to this idea, and I very much appreciate your counsel.
Anyone that runs a Outrage-18 with a 12-inch jack plate...now is the time to chime in!
ratherwhalering posted 05-13-2005 05:19 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
I don't know if there is a retrofit for the Slidemaster, we contemplated exchanging or selling (e-bay) the 12-inch manual if it doesn't work out.
ratherwhalering posted 05-19-2005 03:37 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
Well, the Sea Drive is off:
http://photobucket.com/albums/v641/ratherwhalering/Sea%20Drive/
Removal was not as complicated as I thought. The Engine: We removed the control cables, battery cables, and wiring harnesses, and that was all that was needed. These were run through the transom via a square bracket at the top, you can see hole in the pictures. The square retaining bracket was inside the transom, and bolted to the seadrive. Once removed, the bracket slid down the rigging and was out of the way. We had to remove the bracket so we could push a rubber grommet (similar to the one on the engine coweling) from the outside to the inside of the transom. Then everything slipped through.
The Sea Drive: The hydraulic steering lines, gas line, and oil line all connect to the sea drive unit, and are then routed within the sea drive itself. The connection points were also on the inside of the transom, inside the square cut-out, so we simply disconnected them there. This is a bummer because now the hydraulic steering lines, oil line, and gas lines will be too short, since they basically were measured to end inside the transom. We unplugged the tilt/trim wiring from the motor, which was located in that lower, circular hole. Again, access was easy from inside the transom.
With everything clear, we unbolted the assembly, which was balanced and supported by a multitude of jacks and saw horses. Once the bolts were out, we slowly pulled the boat forward and worked the sea drive off. Man, they used lots of goo. Elbow grease, razor blades, adhesive remover, and simple green did the trick.
The boat is at the fiberglass shop, being repaired, and we hope to have it next week for installation of the jack plate. In the meantime, we are looking for an engine, and have a very good lead on a 1991 Johnson 150 that I think will pan out. I will try to take pictures of the fiberglass repair, and plan on updating this thread with as many pictures and information as possible.
Joe Kriz posted 05-19-2005 04:42 PM ET (US)     Profile for Joe Kriz  Send Email to Joe Kriz
Rob,
What about those trim tabs?
Do you really need trim tabs on an 18?
Just a thought, as now would be a good time to remove them while it is at the fiberglass shop if they are not needed or wanted.
ratherwhalering posted 05-19-2005 05:39 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
Joe, good point, I didn't think about that...might be too late 'cause it's already gone, and repair is underway. I think we'll leave them for now. I suppose we can handle the hull repair if we decide to remove them later.
johnk posted 05-20-2005 09:55 PM ET (US)     Profile for johnk  Send Email to johnk
ratherwhalering, 2 questions, what do you predict the total weight to be for the original seadrive? Sure looks heavy. I would image a significant weight savings going with the bracket and OB. Secondly, assuming much of the work is done by you and your friend, what you you predict it will ending up costing to make the boat ready for new power (repair work/gelcoat/bracket/hardware/etc?), ballpark?
Thank you
kamie posted 05-20-2005 11:54 PM ET (US)     Profile for kamie  Send Email to kamie
Interestingly I found a note on the Commercial site that BW recomends trim tabs on boats under 25 feet. "On models less than 25', trim tabs are recommended to correct for list caused by strong crosswinds and to prevent wind-induced porpoising at high speeds."
ratherwhalering posted 05-22-2005 10:18 AM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
John, I am not sure of the total weight, but it is heavy. I am guessing around 700lbs. I expect that the boat will ride alot higher in the water with just the jackplate, and we will be scraping bottom paint for a few days to get it right. As for price, a local shop quoted $200.00 to drop the sea drive and clean the transom up. Two quotes from fiberglass repair shops. The low estimate for transom repair is $400.00, although this will be highter because we are having some additional, non-related work done. The jack plate and mounting hardware will be about $300.00, however this may increase because I have Brian almost on board for a hydraulic system. I'm slowly breaking him down! Then there is the rigging and engine cost, but that is another story all together.
Kamie, that is a very interesting tid bit! With that in mind, we'll keep the trim tabs for now; they work great and don't seem to be in the way of our project. We'll just wait until we get her on the water to make that call. If they are unnecessary, we'll probably just leave them fully retracted. We got bigger fish to fry right now!
johnk posted 05-22-2005 10:56 PM ET (US)     Profile for johnk  Send Email to johnk
Thanks... So, it's not unrealistic that someone could sink $1500 plus the outboard into a single SeaDrive/OB conversion assuming that they do much of the work while farming out the glass/gelcoat repair.
Best of luck, looking forward to the next round of pics...
John
kamie posted 05-22-2005 11:50 PM ET (US)     Profile for kamie  Send Email to kamie
Rob,
See how she rides with the bracket. Did I see correctly that the tabs are on the raised section of the transom? Most folks have them on the outside edges.
ratherwhalering posted 05-23-2005 12:15 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
John, I figure if you drop the sea drive yourself, and mount the jackplate/bracket yourself, the following is a reasonable cost breakdown:
Fiberglass work: $500.00
Manual Jack plate: $300.00 OR Hydraulic Jackplate: $750.00 OR Stainless Marine/Armstrong Bracket: $850.00
Mounting hardware, odds & ends: $150.00
So from $1000,0.00 to $1,500.00 depending on what your decide re: mounting. Remember, we are not sure if the 12-inch jackplate will allow enough clearance to tilt the motor yet, so this low cost option is not certain yet.
Kamie: Yep, they are located on the raised section. Here is a good shot:
http://photobucket.com/albums/v641/ratherwhalering/Original/?action=view¤t=000_0053.jpg
ratherwhalering posted 05-31-2005 12:59 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
The Slidemaster jackplate arrived on Friday:
http://img.photobucket.com/albums/v641/ratherwhalering/Outrage/WhalerOutrage005.jpg
It looks like it has a built-in 4.5-inches of lift, at the mid-adjustment setting, with 2.5 inches available in either direction. I contacted Chuck Bennett and confirmed that the Outrage-18 has a 14 degree transom angle. I had a friend run the calculations, and with the 14 degree angle, combined with the 12-inch set back, I should mount a 90-degree Jackplate 2.9 inches higher than the standard transom mount. Since this is not a 90-degree jackplate, however, I will be mounting it in the standard mounting position, and adjusting the jackplate (probably down!) to compensate for the 'engine lift' design of the jackplate. I believe that this will be a perfect fit based on the following:
2.9 inches height to compensate for the transom angle. 1 inch height to compensate for the water rise on a 12-inch set back. This should bring the anti-cavitation plate in a comparable position to a standard mount with the anticavitation plate in-line with the bottom of the hull. Add another 1/2 to 3/4-inch height for performance akin to raising the engine 1 hole on the transom, and I'm there.
In other words, Larry was right, the standard transom holes are the correct mounting position for this jackplate. The boat gets back from fiberglass this week, then the jackplate, rigging, Seastar cylinder, and Johnson 150 get mounted. We decided to use the T-H Marine rigging flange and tubing for a clean look:
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=98304
johnk posted 05-31-2005 01:28 PM ET (US)     Profile for johnk  Send Email to johnk
Thanks for keeping us posted. I wonder what that bracket would look like either painted or powdercoated Desert Tan to match the hull? Best of luck..
LHG posted 05-31-2005 02:00 PM ET (US)     Profile for LHG
My experience is that jackplates look best painted to match engine color. Conversely, I think the larger transom brackets (like Armstrong) look best in matching hull color.
ratherwhalering posted 05-31-2005 04:17 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
I suppose painting the jack plate is an option, but I'm O.K. right now with the polished aluminum look. I have the same color set back brackets on my Montauk, and have never felt the need to change color. If the jack plate had an optional color, I would have gone with white to match the Johnson engine, but this was not in the cards.
