| Author | Topic: Mercury 90-HP Four-stroke Unreliable; Carburetor Problems |
| drewc |
Last year I appended a couple of posts re my brand new Mercury 90-HP four-stroke that was hard to start, idled roughly (spitting/coughing/severe engine shake) and then died. Well, here's an update. After 3 months (!) in the shop, the still under warranty engine was returned to me with a "don't really know what's wrong, but we got'er running". After calling Mercury Marine to try to better understand what was wrong, they told me that the mechanic had 'changed out everything", including a computer module, several jets, fuel pump and a few other miscellaneous items. The boat ran well enough to get home, and I enjoyed what was left of last year's summer. Fast forward to this year..same symptoms appeared, same rough idle and coughing. Yes, I consistently renew the fuel and run the engine to make sure nothing gets 'stale". I called for (yet) another service appointment (3rd in less than 12 total engine hours). Two months later I towed the boat in and trailered over to the Boston Whaler dealer. After a week and a half, I got the boat back...they insisted that some fuel had gone bad and gummed up the carbs. Two rebuilt carbs later I had the boat back in the water. Next day I took her out for a high-speed run....boat was up to about 20 knots, back down to 10K for a few moments, then...the engine dies within about 50 feet of the rocky breakwater, LOTS of large rocks. The last thing I remember hearing before she died was the sounded like the fuel pump "clicking" as the engine wound down. of course, the engine would not restart..had to phone a friend to come tow me in while paddling furiously to keep off the rocks. Needless to say I was disappointed in the quality of the repair..obviously, my engine was not repaired. After tieing up at my dock, I tried to restart once again, just to make sure. Engine started, idled roughly, spit and coughed (sounding familiar?), and died. Just like the other 3 times! Frankly I have had about enough of this...a brand new Mercury engine with less than 13 hours should not behave this way. I am interested in hearing from others who have had similar experiences...I know there are many out there because the service manager at the Boston Whaler dealer told me "we've seen a lot of problems with this (90HP four-stroke) engine". I have researched this forum as well and have found numerous accounts of trips and summers ruined from these kind of apparent fuel-related issues. What is being done by Boston Whaler/Mercury to satisfy customers? I am tiring of being told things like "it's bad gas" and "you need to run it more" and other blame-the-user excuses. My two neighbors have 17 Montauks, one with a 2-stroke Johnson 90 and one with a Yamaha -- both start instantly and run flawlessly after sitting sometimes for an entire season. No extra "additives" or precision fuel handling tactics are needed for their families to enjoy these boats.
| dscew |
You deserve a new motor. Run it up the flagpole at Mercury or Boston Whaler. Try to do it through the dealer; if you "get no satisfaction" take it direct to customer service at Merc. Threaten them with a suit as a last resort. |
| bigjohn1 |
I totally agree with dscew; you deserve a brand new engine given your problems and I definitely feel for you in your situation. I would dispute one ascertion though; is it really accurate to say these new 90 4-strokes have been problematic as a whole? Based on the numerous threads I have read on this and other forums for the last 15-18 months, owners of these engines (Merc 90 4-stroke w/Yamaha powerhead) have been pleased overall as a group. I think its possible you may have gotten a "lemon" off the assembly line. I well realize in the frustration of your current situation that you probably don't want to hear this but I think it is generally true. |
| mikeyairtime |
On the 90 four-stroke there are rubber plugs that cap the holes the pilot jets screw into. I discovered this when I was messing with my carbs. I'd never seen this and no one at Mercury could tell me what they were so I wondered if it really needed them or if it was some emissions thing. I did some research and found out if the plugs are left out (or if the very tiny passages from this area to the main jet area are blocked) the motor will run but will not idle. On a motor that sees very few hours a fuel stabilizer should be run and the float bowls should be drained every time the boat is run and even then if you are not turning over your fuel supply it will still be old fuel. My 90 four-stroke has run flawlessly except for one fouled/lean-whiskered plug. I've run the fuel out of mine every time I use it. The guys may be right though, you just may have gotten a lemmon. |
It does sound like a fuel related problem. In your previous article you mention that you keep the boat stored with the engine tilted fully up. I wonder if this is affecting the problem. Perhaps the carburetors don't like sitting in that position for long periods of time. Also, I think you are in California, and perhaps the local gasoline has been formulated in such a way that there are significant problems in storage. I know it is frustrating, but if all the mechanics keep telling you that the problem is bad fuel, perhaps that really is the problem. Since your boat is a MONTAUK (I believe), you probably have on-deck fuel tanks. Have you tried a different fuel tank? I'd change everything I could in the fuel system to see if the problem can be isolated. I do not believe there is an epidemic of problems with the fuel system on this motor. Most people complain about the noisy gear case. |
| whale tauk |
I had a fuel related idle problem with my 2004 90 4 stroke as well. A mechanic that services the Mercs for the Navy on Coronado Island told me that if the boat isn't run every week or so that it's a good idea to drain the bowls on the carbs. He also recommended a fuel stabilizer. He mentioned that in his experience (and he has quite a bit) the 90 Merc has been a good reliable motor. I appreciate your frustration though-in my case I just winched it back up the trailer and went home to sort it out. Drifting near a jetty is another matter. whale tauk |
| LHG |
Darn Yamaha powerheads - they just don't make them like they used to. Try taking it to a Yamaha dealership for service, since that's what it really is, and quit blaming Mercury. |
| drewc |
Thanks to all for your excellent comments and advice. I just heard from the owner of the BW dealer...he tells me that he's got the motor running and that the problem was, he thinks - a rod that snapped off or came loose that connects (and syncs) all three carbs on the Mercury. He says that without this connecting rod in place, the motor would run rough and then die (just as I described to him) in a few moments. After spotting the problem, he reconnected the rod and claims now that the engine runs as smoothly as it ought to (let's hope it stays on from now on.) I am going to take a trip over to the dealer tomorrow to verify the fix, and then, hopefully, take the boat home. I'll let you all know if this is truly "the" fix. Bottom line is that I wanted to let everyone know that it wasn't a "bad gas" issue..sometimes things do fail mechanically and mimic some obvious user-correctable behaviors. I appreciate the dealer being honest with me and taking the initiative to find the root cause of the problem. Thanks again to the group for the help. |
| Clark Roberts |
Drew, your engine has four carbs, not three and if the connection link was not connected then my guess is that it was not reconnected during one of your many services. A loose connedting link would have been spotted by ANY competent mechanic (My nine year old grandson would have spotted that). Larry give good advice to have a Yamaha mechanic check it out. I would take it back and demand a new engine... Clark... Spruce Creek Navy |
| DaveH |
Larry: quote: This is total BS. It's a Mercury product....period. Mercury should face the music and take it back or fix it correctly. If I sold a product with other manufacturers parts on them, I am still responsible for the whole product's performance. General Motors, Ford, BMW, Daimler-Chrysler, etc. all make automobiles but they sub out almost all of the pieces to companies such as Bosch, Johnson Controls, Siemens and so on. Do we as consumers blame Bosch for bad fuel control systems? No, we have GM replace the part or fix it. Don't try to blame Yamaha for Mercury's decision to integrate a Yanaha engine block. If it doesn't work, that's Mercury's problem. I fully blame Mercury and its local mechanic's ability for this. It is unacceptable. |
On the Mercury 90-HP four-stroke engine which uses a power head manufactured in Japan by Yamaha, are the carburetors supplied by Yamaha or by Mercury? |
| drewc |
More information on my situation...in addition to my problem with the throttle linkage "popping off" randomly (to which he said "no way to fix this because that's the way it's designed"), my dealer has advised that "these new 4-strokes (Mercury 90 HP) have very, very tight jets, which are easily clogged (his word) with particulates found in today's cheap (his word) gasoline." He said that some of the problems I was experiencing with "bad gas" was actually sediment left behind as gas in the carbs evaoporates over several days/weeks, gas which "normally" would not pose a problem to 2-strokes or even other (non - Mercury) 4s. It's just that Mercury has apparently made the trade off to use smaller jets to be "more efficient" with regard to gas usage, but with the resultant poor user experience I and many others are seeing. It would be interesting to hear if users of the 4-stroke EFI are having similar issues. To me this is just plain bad design, out of touch with how real people use their products, and with unealistic expectations for most of the readily-available fuels. A Boston Whaler is not a lab experiment, it is or should be (for the most part) a turn-key family appliance. Treat it well, keep it clean, follow the instructions, and it should start and run consistently well, without the need to perform fuel analysis, pressure testing, constant carb maintenance, etc. Naturally I asked the dealer for recomendations for how to keep this engine running...he told me to use their "Mercury Fuel System Cleaner" with every new tank. I asked about "running the engine dry" after use...he said that "you really can't do this with this 4-stroke design", so don't bother. When I asked about additional filtering and water separation, he said "not necessary in my opinion." Nevertheless, I am inclined to put this additional filter inline to add another measure of filtration in the hope I can avoid this mess in the future. Hope this is useful to the board members. |
| bigjohn1 |
ok, now we have more of the story since the dealer is done with it so let's see if we can sort this out. First, I have a 115efi (2004) which is almost an identical engine. Zero problems with gas-related trouble. I must add though that I use Merc's Kwik Kleen or Merc fuel system cleaner in EVERY tank of fuel, alternating the products with each tankful. Assuming you keep your under the cowel in-line fuel filter clean (do you?) the particulates from the fuel will not enter the engine. Did you use a fuel stablizer at the end of LAST season so fuel did not sit in the carbs over this past winter? You may have run the fuel out but did you drain the bowels? It sounds like you don't (or didn't) use the engine much if you're only puting 12 hours on her in a whole year. I'll agree the carb lever falling off is no good but it sounds like that might have been done by your DEALER since you say THEY rebuilt your carbs. Sticking purely weith the fuel issue, I don't believe your dealer's assessment that this is just the way the carbs on this motor are. My dad used to always say there were two types of people: I'm not passing judgement or saying you are either type of person just stating a general fact that I believe based on what I have experienced over the years with cars, boats, weed eaters, generators, lawn mowers, chain saws, and motorcycles. I'm still waiting for someone to backup the claim that there are numerous problems on the 90 4-stroke Merc. I am not a brand loyalist and would just as easily be operating an E-tec or (other outboard) if that's what came on my 2005 170 MONATAUK. Still, I have to be honest that in 5 Merc outboards, none of them have let me down. None of the older OMC outboards my family owned let us down either though so its a toss-up. I think you need to be running Kwik Kleen and Merc fuel system cleaner in your gas and also need to run some stablized fuel through your system this fall. Then tell us next spring if you have these same problems. |
| gnr |
"Darn Yamaha powerheads - they just don't make them like they used to. Try taking it to a Yamaha dealership for service, since that's what it really is, and quit blaming Mercury."
I'd still like to know whose carburetors are used on that engine. Even though the powerhead comes from the Orient, Mercury has used their own fuel induction on other engines in this series. On the 115-HP they used their EFI system, and now have it on the 90-HP. So it would not be beyond belief that the carburetors on the Mercury 90-HP four-stroke are from Mercury. Take a look at them and see if there are any identifying marks. As for the powerhead, it is all Japanese content. I read somewhere (sorry for the vague citation) that Yamaha makes so many of these that they have a separate production line for the Mercury version--there is enough difference from the Yamaha model that they can't be built on the same line. I agree with drewc, the engine should run in real-world circumstances. If the engine sits for a couple of weeks, you shouldn't have to overhaul the carburetors. But one thing does not make sense: if the problem is sediment from the fuel, why would the mechanic/dealer not recommend a better fuel filter? |
| littleblue |
I think all that gasoline trouble they are feeding you is a load of sh*t. Who in their right mind would ever develop a boat engine that sensitive to fuel issues? There are tons of those 90 4strokes out there, and if it were mandetory to add fuel stabilizers, system cleaners, run the carbs dry, etc. so frequently, there would be problems popping up all over the place. In my opinion, they are feeding you a bunch of crap. If your engine even hints and running funny again, I would demand a new one. And if they refuse, law suit time. You deserve a new engine just based on principle..."run mercury fuel system cleaner w/ every tank"...please, gimmie a break. |
| LHG |
Jim, from what I understand, the entire engine comes from Yamaha, including carbs, EFI, etc. None of these engines are Smartcraft enabled, so that rules out Mercury's EFI, which is. The different assembly line is for the black paint jobs, and possibly some need adaptations to fit the Mercury controls, cowls and mid sections? All of Mercury's own 4-strokes have had EFI for some time, but they couldn't offer it on the 75 and 90's since Yamaha wasn't making it? If you remember, during the dumping investigations, Yamaha made a big deal out the fact that Mercury was so inept in bringing 4-strokes to market on a timely basis, that they had to buy COMPLETE engines from Yamaha for this 75-115 segment. I would have to agree with DaveH in that even if Mercury got a bad engine from Yamaha, they would be stuck with the corrective measures. The sooner they get the Verado based EFI models out in these HP ranges, the better off they will be. Only one more year to go. By next year at this time the Verado based engines are supposed to be shipped as 2007 models |
| bobeson |
I own a 2003 Mercury 90hp 4-stroke on my 2003 Montauk 170, and I have also been having fuel-related problems ever since my first child was born last year. As you might expect, I have found it challenging to use my boat regularly this year. I have been forced to cancel two different trips at the launch ramp this year because of fouled carbs, including the NorCal Rendezvous, unfortunately. I finally rebuilt the carbs a few weeks ago and so far have had much better luck with my engine. The carbs are Keihin branded, and do feature an abundance of very tiny passages that were clogged with gummy fuel residue. Rebuilding was simple enough, and all of the gaskets were reusable in my case, which is good because Merc wants $110 per carb (x4) for the rebuild kits. The biggest obstacle I faced in the rebuilding process was agonizing over the choice of which carb synchronizing tool to purchase. I hate the mercury-tube-style synchronizers, and wanted to purchase a solid state tool, and ended up with the $700 (ouch!) VacuumMate, which works very well. I was told by my Whaler dealer (the Outboard Motor Shop) that the engine powerheads are supplied by Yamaha, but only the top-end is actually a Yamaha design. The guy I spoke with claimed that Mercury designed the bottom-end (crankshaft & such) to mate with their lower units. I gathered that Yamaha is assembling their top-end onto Merc designed (and Merc-supplied? dunno) bottom-ends and shipping the powerhead assembly to Merc for final motor assembly. I don't have any actual confirmation of the details of this process, however. The mix of metric and SAE fasteners I encountered seems to lend support to this notion. I sure wish I had been able to purchase the 115hp EFI engine instead of the 90hp carb engine. I really don't like carbs, but I didn't want to undertake the repower myself (and the dealer said they wouldn't do the repower). I'm still considering it, although I doubt I'll actually spend the money until this motor starts giving me much more serious trouble (i.e. the wife becomes worried enough for my safety to support the expenditure :-) Also, Merc recommends mid-grade fuel, not premium or regular unleaded. I have suspicions that this fuel, because it is the least-popular grade, may tend to be older than other grades at your typical gas station, and this might in some small way contribute to the fuel troubles I've been having. I'm tempted to switch fuel grades, but don't know much about details of which direction to go. I'll probably start buying regular unleaded and use my own additives. Can anybody offer more definitive guidance on fuel grade choice for this motor? Should I use an octane booster with regular grade, along with cleaners and stabilizers? |
| bsmotril |
This site has some good info on Gas grades: http://www.maxrules.com/fixgas.html |
| dgp |
Use a Top Tier Gasoline http://www.toptiergas.com/ . I know Chevron and Shell qualify for Top Tier rating in all grades. |
http://www.keihin.com/ makes carburetors in New Berlin, Wisconsin. It sounds to me like the carburetors on the Mercury branded 90-HP four-stroke engine are added by Mercury. It seems unlikely that a Japanese company (Yamaha) would buy a carburetor in Wisconsin, ship it to Japan, assemble it to a powerhead, and them ship the whole thing back to Wisconsin. Unless someone has more evidence, I'd say the carburetor on that Mercury engine was added by Mercury. Call Fon-du-lac to complain, not Tokyo. |
| bigjohn1 |
bobeson: was your fuel properly stabilized LAST YEAR prior to winter layup? I keep wanting to bring this fact up in the thread just to make sure we are progressing and blaming the right part or procedure. |
| bobeson |
Jimh, Keihin is a Japanese company with global manufacturing operations. They have a page on their main corporate web site that gives an overview of the products manufactured at different locations. They do not mention the manufacture of carbs in the US, only the sales office for them in their New Berlin, WI facility. Check this page for more details: http://www.keihin-corp.co.jp/english/network/overseas/index.html I believe that they are manufacturing these carbs in Asia, not the US. Keihin and Mikuni are the two carb vendors of choice for all of the Japanese motorcyle and outboard manufacturers, as far as I know. It looks like Keihin makes their carbs in Japan, China, and Taiwan, with a new facility in Brazil under construction. bigjohn1, I did not add stabilizer last year prior to the extended period of non-use. I certainly do blame this as the primary cause of the carb failures I experienced. My musings about choosing a new grade of fuel are not meant to blame newly-purchased "old" gas, rather I am just looking to optimize whatever gas I do purchase. I still blame the inherent design of carbs as being susceptible to these problems to a much larger degree than EFI engines. |
| fishinchips |
I also have a 2003 - 90hp Merc with the carbs. I use chevron regular gas with Merc/Quicksilver Quickleen. Put in some of that quickleen every time i gas up. No problems. You don't really need to put quickleen into the tank every single time, but its a habbit and I am not having problems. If you use your boat every week, then you won't have carb problems, but alot of us don't. So its a good idea to put some quickleen. Went to outboard motor shop (dealer) and noticed on there NEW montauk 170 that it had a fuel injected 90 hp 4 stroke Merc. Ken |
| bigjohn1 |
bobeson: I'm not getting on your case but I did want to establish that fact (use of fuel stabilizer) in an effort to narrow down a cause. It might be a combination of the fuel and the carbs on the 90 4-stroke but any engine (boat or otherwise) will suffer problems with old gas left in it. I personally have the 115efi but I would be willing to bet the farm if I put my boat up for an extended period of time without adding a stabilizer, I'd likely have the same problems you are experiencing. |
OK--now we're back to my original question: Who put the carburetors on the Mercury 90-HP four-stroke? Yamaha or Mercury? |
| mikeyairtime |
The fact that they're Keihin carbs leads me to "assume" that the powerhead came from Yamaha carburated. |
| bsmotril |
Why do you say Kehins are Yamaha? That make of carb is used on all Harley Davidson bikes, and they are not a Japanese company? Also used on some of the jet skis made by See Doo. BillS |
| goinboatn |
This site cracks me up! Whaler makes a great boat it's just too bad they make you buy a Merc! I know you have heard this before from your happy neighbor. I grew up running a 1984 Yamaha 90 every day wakeboarding/fishing etc. Never had a problem started every time, still runs great! There is a reason Yamaha comes up in CONTINUOUSWAVE threads so often--because they are the best outboards on the market.! My whole life I have seen Merc's at the ramp trying to start and when they do smok'n lol! Is it me or do top of the line boats always come with a Yamaha, that is except for whaler, then again whaler is owned by a comglomerate so maybe pathfinders should be in everyone's future. perfection = old whaler-new Yamaha ;-) |
| LHG |
Who makes the carburetors found on the Yamaha F75 and F90? Probably the same Japanese company. |
| bigjohn1 |
This thread cracks me up - drewc has a fuel/carb problem with his outboard which is on its second season but only has 13 operating hours. He wants to find out if others are having like problems but only one other person responds with the same problem...BUT that person admits his boat/engine WAS NOT properly prepared for extended layup. We go round and round about who makes the engine, what brand of carbs are on there, and where the carbs are made. drewc: I originally thought you might just have a lemon and that indeed might still be the case. Still, only one other person chimed in with a like problem for the 90 4-stroke and he admits he left old gas in his boat. I view this whole saga as an isolated incident. |
| mikeyairtime |
News flash, your Harley has Japanese carburetors. Keihin is a Japanese company, make no mistake about it. My 1965 Honda 50 Dream has a Keihin carb. Keihin has been supplying the big 4 Japanese motorcycle brands for decades, of which Yamaha is one. Keihin also makes very high performance carbs used in motorcycle road racing and motocross racing. Just cause a Japanese company manufactures in the US it's still Japanese hardware. |
"Keihin" sounds Norwegian to me. Sounds like two bachelor Norwegians, Kiiko and Yerke Keihin. Probably used to work for Ole Evinrude in the way back. |
| bobeson |
bigjhon1 - I think you are conflating a number of sub-topics within this thread into a strawman argument that of course doesn't make sense as a single point. I don't think anybody is trying to argue that the cause of drewc's or my frustrations with our motors has anything to do with where our carbs were manufactured. I did not "admit" that my failures were my own damn fault - this somehow makes it sound like I reversed course after trying to blame a product manufacturer for my problems. I explained from the start that my problems were due to nonuse, and never tried to imply otherwise. I suppose the title of this thread, and perhaps the direction of some of drewc's initial expressions of frustration, may lead one to conclude that this entire thread is bashing manufacturers, but I don't think that's the case. Nor do I think it entirely accurate to say this "saga" is an "isolated incident." The fact is, engines with carburetors are prone by design to experiencing the sorts of problems discussed here. I would not go as far as to support the implied claim of the title of this thread (which currently is "Mercury 90-HP Four-stroke Unreliable") but I do think it informative to discuss the issues we have faced for the sake of others who are likely experiencing similar failures, no matter who is to blame for them. |
| WT |
drewc: Call the Outboard Motor Shop. For around $2000, they will swap out your carburetor 90-HP for a new Mercury 90 EFI. :) Warren |
| bigjohn1 |
bobeson: ok, fair enough (I guess). I tend to get worked up a bit when I feel a product is getting blamed when it shouldn't. I can definitely understand how damn frustrating this was for you having to re-build your carb. Still, since you and I have both succesfully re-built a carb, we both know ALL carbs (regardless of brand) have an abundance of tiny fuel and air passages that can get clogged. I own Merc currently but have owned older OMC outboards as well, they are all basically good products that will take care of you if you take care of them. Not so much on this forum but on a couple of others, you see so many people chime in with a particular problem that they blame on a manufacturer - but when you read betweenthe lines, it oftentimes id something they did not do correctly. CASE AND POINT: Just for kicks, go over to The Hull Truth and monitor the BOATING message board for two whole weeks. In that time, you normally will see 4-5 people chime with an engine problem that, in many cases is their own fault and they are bashing the manufacturer. Here's a representative example, SUBJECT: "Evinrude 250 is junk - HELP!" Text: "Gang, I was out over the weekend and this peice of crap Evinrude started running rough at high rpm. It progressively got worse to the point where the engine stopped running and we had to get a tow home. I am totally pis$#@! off and will never buy another Evinrude as long as I live. My buddy's cousin had the same engine with the same problem - Evinrude has a problem on their hands!!!!" Most of us are adept enough at critical thinking to ask the questions to get to the bottom of a thread like that. There are too many who are not though and will simply take this guy's statement as fact and start passing on a rumor that all Evinrude 250's are total junk. Oftentimes, what comes out in subsequent postings is the fact that the owner did zero maintenance and simply added gas and expected his engine to magically run like a top forever. Good luck with your engine...I think you have a reliable one and can expect years of trouble-free useage from it. But do stabilize the fuel....then, if you have these same problems next year, I'll eat my words:-) |
I think it is reasonable to expect that a new motor run reliably. This expectation is reasonable no matter if the motor is a Mercury brand or not, if it has carburetors or not, and if it gets used daily, weekly, or monthly. It is also reasonable to expect that if you take a new motor to a dealer who is authorized to service it that they be able to find fundamental problems like mechanically disconnected throttle linkage between multiple carburetors. I think it is reasonable to expect that a carburetor not become clogged repeatedly when its pattern of use is non-continuous. I think this expectation applies no matter what manufacturer made the carburetor, what continent it was made on, and who bolted it onto the engine. I don't think it is reasonable to abandon all hope that an engine with a carburetor will operate reliably just because there is now a similar engine available with fuel injection. The existence of other technologies does not foreclose or prevent previous technologies from continuing to perform as they always did. There are two possibilities here: the engine is not working as designed and has an problem that needs repair; or, the engine is working exactly as designed but the pattern of use is causing the problem. If the engine has a problem that needs repair, the remedy is to get the problem diagnosed and fixed. Keep taking the engine back to the seller until he makes it run correctly. If the engine is working as designed and the unreliable operation is because of the pattern of use, the grade of fuel, the orientation of the motor during storage, or other factors which cause the carburetors to become fouled and clogged, it is very likely the engine will continue to repeat that behavior unless you change the pattern of use, the grade of the fuel, the orientation of the motor during storage, or other factors causing the problem. A problem like this is not self-healing. It won't go away unless you change something. |
| bsmotril |
Hey Mikeyairtime. I know what my Harleys have. In my post I was just trying to figure out how you make the jump in logic assuming just because the powerhead has a Kehin that it is Japanese block when there are plenty of American made products that use the same carb. It's a global economy now, and these days you can't assume a country of origin based on any one component. That is the point I was trying to make, which you so nicely reinforced in your comeback. Thanks. BillS |
