Topic: Positioning stern light standoffs
SpeedBump |
posted 08-28-2005 06:29 PM ET (US)
what is the correct position for mounting the stern light knerled nut standoff for an N-S-E hull configuration? Does the standoff base with the nut go above or below below the standoff base w/ out the nut?
Tom W Clark
posted 08-28-2005 08:32 PM ET (US)
On all small Whalers the "knurled nut" goes on top. |
SpeedBump
posted 08-29-2005 08:16 AM ET (US)
Tom thanks for the info - I thought this was the correct positioning but wasn't sure. I had looked at a newer montauk w/smirk and the standoff w/ nut was on the bottom. It looked hard to get to, to tighten and loosen the nut. |
Robob2003
posted 08-29-2005 10:13 AM ET (US)
I have the same setup on my Sakonnet with the knurled knob on top.Because I couldn't find an OEM part I had to make a compression ring to fit into the knurled knob to hold the staff tightly. I found that making one out of a white crutch tip worked great. Just put it in a vise and drill out the center to the right diameter and trim off the outer diameter to fit in the knurled knob. Bob on Tampa Bay |
Tom W Clark
posted 08-29-2005 10:49 AM ET (US)
You can put the knurled nut on the bottom. It does work that way, just less convenient.Bob, The split washer (compression ring) is available from any Whaler dealer. They cost about $2. |
Robob2003
posted 08-29-2005 02:46 PM ET (US)
Tom,Thanks. I wish I had known that a year ago, it's easier than manufacturing one. I'll zip up to Marinemax and buy one. Bob on Tampa Bay |
Tom Hemphill
posted 05-05-2015 06:10 PM ET (US)
Reviving an old thread here...When I acquired my 1970 16-foot Whaler, the fitting with the knurled nut was mounted in the lower position. (No idea who installed it or when.) I moved it to the top position recently after having the fittings re-chromed. I think moving it was a mistake; now dock lines and such are more likely to catch on it, since it projects upward. |
contender
posted 05-08-2015 03:50 PM ET (US)
Tom H. I saw the same problem with the rear light pole, I attach (mounted mine flat, no pole) my rear light to my engine cowling. Now I have the light ready all the time, no pole to get in the way, and no exposed wires to rot or get in the way, no terminal block either, and lot cleaner looking |
