  King Starboard Seats/Storage Boxes-Revenge 25
Author Topic:   King Starboard Seats/Storage Boxes-Revenge 25
macfam posted 12-01-2005 08:10 PM ET (US)   Profile for macfam   Send Email to macfam
After receiving Tom W. Clark's CD I noticed that many 25 Revenge WT had OEM storage boxes behind the helm seats. They also had seat cushions which would allow more generous seating.
It really made sense to me, because the deck space was enormous compared to my former Revenge 20. And I needed more seating for guests.
In addition, I wanted to install a fresh water washdown system so I could flush my Yamaha, and freshwater wash the entire boat at the mooring after a day out on the (salt)water. And, any more useful dry storage was more than welcome.
So I found a source for King Starboard sheets and set out to make my own seats/storage boxes.
After careful measurement for size and location, I decided to construct these boxes with as little joints and SS hardware as possible. So the sides of the boxes are one continuous piece that was bent(by heating with a gun)and then finnaly joined with a spline and 3M Scotchweld 8005 2-part epoxy/adhesive. The tops are simple Starboard squares fastened w/ SS hinges and spring locks.
Then they were mounted like mini-helm consoles to the floor using strips of finished mahogany and SS faasteners. They are solid! And have put up with 2 seasons of pounding, sitting, standing, jumping etc. etc.
Here are some pictures of the KING STARBOARD seat/storage boxes I took last week as I was winterizing.
http://img.photobucket.com/albums/v333/macfam/Closedseats-strorageboxes. jpg
http://img.photobucket.com/albums/v333/macfam/Openseats-storageboxes.jpg
The 13 gal. freshwater washdown system with bladder, pump and 25' hose coil & nozzle.
http://img.photobucket.com/albums/v333/macfam/Openfreshwaterbladder.jpg
And finally, the extra storage used for cleaning/maintenance products etc. (but it could be used as a livewell)
http://img.photobucket.com/albums/v333/macfam/Openseatstorageboxrt.jpg
I can't tell you how handy these units have been. With a regular seat cushion on top they are quite comfortable and the freshwater washdown and extra storage has been really great.
Chuck Tribolet posted 12-01-2005 09:38 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
It looks like you cut a dado about half way through the
Starboard at each corner. It seems to have worked out.
Could you share the dimensions (thickness of Starboard, width
and depth of the dado?
Thanx
macfam posted 12-01-2005 10:34 PM ET (US)     Profile for macfam  Send Email to macfam
Chuck,
The thickness of the Starboard is 1/2 inch.
The dado is 1/4 inch deep and 1/2' wide.
I first tried the bend w/ no dado, and at least the first attempt had a bit of wrinkle on the inside.
So I tried w/the dado and it bent very easy w/ the heat gun.
I was uncomfortable having only 1/4" on the corners, but it has been quite sturdy thus far.
If I were to do it again, I would attempt with a scrap piece to do without a dado or make it 1/8 inch to see how it bent.
Peter posted 12-02-2005 07:39 AM ET (US)     Profile for Peter  Send Email to Peter
Neat! Nice work.
Capt PEI posted 12-02-2005 11:20 AM ET (US)     Profile for Capt PEI  Send Email to Capt PEI
Great work.I was looking at an old accessory catalogue last evening and looking at the OEM storage seats. The seats look to have the pedestal mounted on the storage units. Did you put bottoms in the boxes? and how did you get around the pedestal bases? Maybe a project for my Revenge this winter.
Tight lines
Roger
macfam posted 12-02-2005 02:37 PM ET (US)     Profile for macfam  Send Email to macfam
Roger,
The boxes are mounted just behind the pedestals, almost touching. Maybe an inch clearance. So, pedestals are still mounted to the floor as from factory/
The box holding the pump and water bladder has no bottom.
The pump is mounted directly to the deck in the box, and the wiring is underneath the deck. The box is mounted to the floor(deck) with finished mahogany strips, and then screwed by stainless screws and finish washers. That box is not sealed to the floor with any sealant, so that if water is spilled during the filling of the bladder it simply seeps out from under onto the deck and drains aft.
Oddly enough, the other box holding the cleaning supplies does have a bottom, and it is sealed to make the whole thing water tight. This was accomplished by cutting another dado all around the box about 2 inches from the bottom and installing the bottom at assembly before epoxying the seam.
Then I used sealer (3M 5200 I think) to seal the bottom water tight. I had intentions of using this as a possible livewell, but never have. But if the hull cleaner, or Yamalube or Mary Kate cleaner leaks, it's trapped in the box so NO spillage on the deck.
The top caps or lids are simply cut KING STARBOARD
macfam posted 12-02-2005 02:41 PM ET (US)     Profile for macfam  Send Email to macfam
Oops! Hit the enter by mistake!
As I was saying....
The lids are cut KING STARBOARD (Seafoam) and the upper edges and corners routed smooth.
All hardware is Stainless, the stainless has held pretty good, but occasionally have to be cleaned/polished up a bit of slight corrosion. (Probaably cheap foreign stuff)
Mike Brantley posted 12-04-2005 03:03 PM ET (US)     Profile for Mike Brantley  Send Email to Mike Brantley
Macfam, those storage boxes look great. I will have to consider a similar project for my Revenge. Do you have any photos of the boxes with the seats installed?
I had considered making larger boxes with the seats attached directly to them instead of smaller boxes behind the pedestals as you have done, but your approach may be better for me.
macfam posted 12-04-2005 04:03 PM ET (US)     Profile for macfam  Send Email to macfam
Mike,
I don't have pics with the seats installed.
I was winterizing last Sunday when I remembered that I meant to take pictures a year ago for posting on CW.
I had already pulled the seats off the pedestals and packed them away.
I remove the seats each winter, because I have 3, aluminum stepladders that I use to support the tarp for the winter.
I place the 3 ladders, tie them down, and tie and duct tape a 1 inch PVC backbone from pulpit to stern, then bungee a tarp in place.
With the seats removed, one ladder fits perfectly between the pedestals.
If I can give you any more info about the boxes, just let me know.
Bulldog posted 12-04-2005 04:57 PM ET (US)     Profile for Bulldog  Send Email to Bulldog
I'm thinking about doing the same thing next spring, I'm planning on buying two "Double Companion Storage Seats" from an Arima boat dealer in Maryland. I saw a Revenge with one installed with the factory seat on the front and a Halls matching custom cushion on the rear section. I'm planning on using two blue throw cushions velcroed on for the rear. [www.arimaboats.com]The color was a good enough match that I thought they were factory for a second! I think he said the price was about $150 each....Jack
