ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Repair of a Pate Tank
Author | Topic: Repair of a Pate Tank |
JayR |
posted 03-01-2006 05:05 PM ET (US)
I purchased a 24 gallon Pate tank for my Ribbed Outrage some time ago. Unfortunately, it was damaged by UPS in transport. In the end, I got a refund for the purchase price of the tank and was left with just the shipping charges. As this was a used tank from another forum member, I found myself very fortunate to have a tank that could likely be repaired for the sum of $35 more or less. After sitting in my garage for a long period, I finally got around to patching the damaged corners and several cracks. The corners were cleaned up and the surrounding area sanded with 80 grit paper on a random orbital sander. West system epoxy thickened with micro beads was used as a filler. It worked out very well. I'll add that the epoxy was from a 3 year old opened container and that the pumps worked as they should have and provided the correct amounts for a proper cure. I had my doubts.... Once cured (several hours) it was sanded flush and degreased. I am coating the exterior of the tank with a copolymer paint (rubber). It only came in the basic colors (white, grey and black) so I brought the white copolomer to Lowe's and they tinted it to match the hull for free. Here it is in progress. The product requires several coats and a flat surface as it runs readily. http://img345.imageshack.us/img345/7987/030120060029sc.jpg BTW... the tank was pressure tested and has no leaks... |
