ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Yamaha 70-HP: Water Pump Service
Author | Topic: Yamaha 70-HP: Water Pump Service |
bretm1 |
posted 03-27-2006 08:25 PM ET (US)
I dropped lower unit from my Yamaha 70-HP two-stroke outboard motor, and I have installed water pump. I need to get manual, but have been going off what I learned here. Did I need to loosen any screws under the engine cover?? I did but I do not think it was neccessary. Second, I have a two inch diameter o ring that I can not figure out placement for. Give me ideas. Did I need to remove the prop? It was not too bad at all, so far. I will also replace thermostat and plugs (after I fire it back up w/old plugs first) Thanks-Bret |
posted 03-27-2006 08:46 PM ET (US)
The factory service manual or even a good after-market service manual would be the first tool I would recommend to a do-it-yourself outboard mechanic. |
John from Madison CT |
posted 03-28-2006 09:06 AM ET (US)
Go to this site for phenomenal Yamaha help: http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=forum;f=30 |
