| Author | Topic: Weight of Older Outboard Motors |
| shipwreck8 |
Weight of Older Outboard Motors What is the weight of a 1976 Johson 85-HP engine? I am thinking of re-powering with a Yahama 90-HP four-stroke and I was told the weight of the Yamaha and the wieght of a 1976 Johnson 85-P are close. Thanks. shipwreck8 |
| Tom W Clark |
Weight of Older Outboard Motors A 20-inch shaft 1976 Johnson 85 weighs about 300 pounds, maybe a bit less if it does not have power tilt and trim. |
| shipwreck8 |
Weight of Older Outboard Motors Tom, Thanks, what do you estimate the weight to be if it has a 25-inch shaft? Thanks shipwreck |
| Tom W Clark |
Weight of Older Outboard Motors The 25-inch shaft length adds about five pounds or so. |
I would be glad to collect, organize, and publish the weights of some older classic two-stroke engines. If you have data on various engines, feel free to append it to this discussion. |
| Tom W Clark |
Weight of Older Outboard Motors The weight of the 25" Yamaha 90 four stroke is about 375 pounds, a LOT more than the old Johnson 85. Somebody is feeding you a line. |
| whalerron |
Weight of Older Outboard Motors 1975 Johnson 70 hp with standard shaft - 202 lbs |
| RussAdams |
Weight of Older Outboard Motors Here's the numbers I have for a 1988 Johnson 40HP: Remote, Electric, Short Shaft - 180 lbs |
| Thorne |
Weight of Older Outboard Motors 1987 Johnson 70 Long w/tilt......284 lbs |
| Peter |
Weight of Older Outboard Motors The following are typical OMC motors and weights found on classic Whalers. Weights taken from the 1992 Evinrude catalog. 2 cylinder, 521 cc platform, 20/25/30/35 HP This bullet proof motor platform had a run from 1976 to ~2005. Often found on classic 13, 15 & sometimes as twins on 17 Montauks 2 cylinder 737 cc platform, 40/48/50/55/60 HP These motors populated the transoms of 13s, 15s and some 17 Montauks. 3 cylinder 849/920 cc platform, 50/60/70 HP 20 inch shaft, elec. start, man. tilt -- 237 lbs (This motor used to displace ~849 cc and was about 10 lbs lighter) Often found on 15s, 17 Montauks, sometimes as twins on 18/20 Outrages and 20 Revenges. V4 1632 cc platform, 85/88/90/100/115 HP 20 inch shaft, elec. start, man. tilt -- 288 lbs Often hanging on the transoms of 17 Montauks(85-100 HP), 17/18 Outrage (115 HP), 22 Outrage/Revenge as twins (90-115 HP). V4 2000 cc (loop charge) platform, 120/130/140 HP 20 inch shaft, elect. start, trim/tilt -- 365 lbs Seen on 17/18 Outrages & as twins on 22 Outrage/Revenge incl. WD, 22 Outrage/Revenge Whaler Drive ("WD"), 25 Outrage/Revenge incl. WD. V6 2448 cc (cross flow, 90 degree) platform, 150 HP 20 inch shaft, elec. start, trim/tilt -- 397 lbs V6 2589 cc (loop charge, 60 degree) platform, 150/175 HP 20 inch shaft, elec. start, trim/tilt -- 370 lbs Often seen hanging on the transom of 18 & 20 Outrages, sometime on 22 Outrage/Revenge (as single) & on 22 Outrage/Revenge WD and 25 Outrage/Revenge as twins. V6 3000 cc (loop charge) platform, 200/225 HP 25 inch shaft, elec. start, trim/tilt -- 455 lbs. (This platform started out with lesser displacement (~2700 cc) and slightly lighter weight) Commonly seen on 22/25 Outrage/Revenges as singles and sometimes as twins on 25 Outrage/Revenge/Temptation WDs. V8 4000 cc (loop charge) platform, 250/275/300 HP 25 inch shaft, elect. start, trim/tilt -- 555 lbs Sometimes found on 27 Whalers both notched and WD. (This platform also started out with lesser displacement (~3600 cc) and slightly lighter weight) I am missing the data for the mid 90s 60 degree V4 loop charged platform which was sometimes found on 17 Montauks and 17 Outrages.
| Binkie |
Weight of Older Outboard Motors According to the manual, 1987 Suzuki DT150, and DT200,both V-6, 20 in shaft 2 stroke weigh in at a heavy 456 lb. A 25" shaft motor is 465lbs. |
| Binkie |
Weight of Older Outboard Motors 1956 30 hp. Johnson or Evinrude according to my memory weighs 97lbs. When the 13 foot Whaler was designed, this was the most common motor that was used on that boat. A lot lighter than the motors used nowadays. |
Weight of Older Outboard Motors Peter--Thanks for the excellent summary of OMC motors. Perhaps one of our many Mercury motor fans can do the same for their engines. |
Weight of Older Outboard Motors Please append information on the weight of older motors to this discussion. We will move the discussion of re-powering and comparative performance to a separate thread. |
| Brys13s |
1987 Mercury 35, no p/t,remote 214#. |
| The Judge |
Weight of Older Outboard Motors What do you need? I have about every OMC, Mercury, Mariner, Suzuki, Yamaha, brochure from the 70's, 80's, 90's, etc. I probably have 100 brochures. I also have option brochures for OMC as well from the 70's + 80's. A 1974 OMC 85hp weighs 267lbs A 1977 OMC 85hp weighs 270, 298 with PTnT. 320 in 25" with PTnT. |
| The Judge |
Weight of Older Outboard Motors FYI...1987 Merc 35hp is 148lbs with electric strt no PTnT 20". |
| The Judge |
Weight of Older Outboard Motors 1991 Mercury brochure states the following: 9.9 + 15hp...69 & 71lbs Compare to 1977 brochure: 7.5 + 9.8hp...64 & 71lbs-ES(elec start) Compare to 2001 brochure: Four strokes only Optimax only: 2 smokes only: |
| oliverweagle |
Weight of Older Outboard Motors What is the weight of Mercury 1985 35-HP outboard? Thank you--Matthew. |
See above. |
| JayR |
Weight of Older Outboard Motors [What is the weight of a ]Bearcat 85? |
| PeteB88 |
Weight of Older Outboard Motors From Owner's Manual, 1992 Yamaha Marine 40 and 50 HP 40 D, 151.8 short 156.2 long MANUAL START, CONTROL Weight in pounds. Manual copyright 1989 |
| montauk steve |
Weight of Older Outboard Motors [Tell me the weight of] an 1983 Evinrude 90-Hp |
| NWB |
According to the 1981 Johnson brochure, a 90-HP 20'shaft with power trim weighs 301 pounds. |
| Teak Oil |
Weight of Older Outboard Motors It is about 305-310 with a prop, gear lube, trim fluid, etc. |
Weight of Older Outboard Motors [Consolidated another discussion on this topic into this discussion; the other discussion was removed.] |
| sraab928 |
Weight of Older Outboard Motors I usually go to NADA online guides - They list boat and motor weights when you look up values. I am not sure how accurate it is but I would think it is close. I got the weights for the following 1987 models assuming power tilt and trim. Mercury 70ELPTO - 265 Pounds Hope this helps out. |
| The Judge |
Weight of Older Outboard Motors 288 for the merc with PTnT. I show 250 even for the OMC. To answer the question asking if NADA weights are incorrect: No the 265-lbs is correct for the 70 merc in NADA but that is w/o PTnT. With PTnT it is 288. All of my brochures claim the 70 OMC at 250 with PTnT and I think 237 w/o. |
| Sarge |
Weight of Older Outboard Motors I have searched high and low but can't find any specs on the weight of the 1986 Evinrude 150 HP V6 outboard. I want to compare that to the weight of the various modern alternatives for repowering... Thanks in advance for the magic answer! |
| Peter |
Weight of Older Outboard Motors About 390 lbs give or take 10 lbs. |
Weight of Older Outboard Motors [All questions about the weight of older outboards are moved to this discussion.] List recompiled by pisano
| A2J15Sport |
The OMC crossflow V-4's (99.6 cid block) also came in: 110, 112 (SPL models. 1980's and 1990's) 100, 125, 135, 140 (1970's) The pre-1972 models were electric shift. 1973 and later were two cable hydraulic assist-"Power Shift II". All the V-4's (crossflow-1969 and later) were right about 300-310 pounds. |
| jgkmmoore |
I'm about to buy/restore a 1977 Johnson 200hp V6 (non-running)engine.Can't find specs. Need to know..the weight. |
| The Judge |
I think they weigh about 370lbs, are DEFINATELY cross flow gas hogs (but bulletproof). |
| footsie |
Everyone seems to be overlooking what would appear to be the lightest weight 30 hp motors. Tohatsu/ Nissan built these strong 2 cylinder motors up thru 2001. Their weights vary from 101 to 108 lbs. |
| cgodfrey |
JimH, is collecting this information still important to you? If it's not already compiled somewhere, I believe I can make a spreadsheet with the weights of most of the OMC outboards of the 1950's - 1970's from OMC's promotional literature. CG |
| number9 |
Jim, Same question, don't have a spreadsheet but do have some accurate info on a few motors. |
| SJUAE |
I think LIQUIDNIRVANA website has all sales brochures since 1909 for Evinrude, so you can find almost all data you want here: http://community.webshots.com/user/LIQUIDNIRVANA2 Regards |
I don't see any value in a spread sheet. There are no computations to be performed and the data will be static. A nice listing of motors and weights would be great. I am not a fan of pictures of information. I like information in text, not in JPEG image files. |
| SJH |
1989 Evenrude, 90hp, 20"shaft with PTnT 302 lbs. |
| SJUAE |
Jim Agreed tabular format is much easier. I simply pointed out to cgodfrey where he can find any missing data for his compilation. Regards |
| Don88outrage |
Here's the NADA listing, don't see anything related to shaft length unless that's tied to model no. [url]http://www.nadaguides.com/default.aspx?LI=1-24-0-5601-928-994-60566&l=1&w=24&p=38&f=5693&gc=mr>c=ob&any=0{/url] |
| Don88outrage |
Try |
