posted 07-26-2006 06:08 PM ET (US)
Hello-I owned a Dauntless 13. At anchor, I had a problem with water entering through the scuppers and running forward if someone was in the front fishing seat. It was not much water and did not present a problem..just a minor inconvenience. It ran out when we got underway and never made the hull spongey.
Chuck bennett at Whaler sent me a pair of rabuds that I installed over the scuppers which corrected the problem.
it sounds like your problem may be more extensive. If your floor is spongey, I suspect you might have a more serious problem. The hull might need special attention to get it dried out properly.
I would email Whaler for advice.
Good luck.
David
