Topic: HONDA BF90: Clean Carburetors Run Like New
bobgilsp |
posted 06-16-2008 03:20 PM ET (US)
My 1996 Honda BF90 developed stalling problems when transitioning from idle to mid-RPM, and it wouldn't [reach] near its 6000-RPM redline. I tried [a fuel additive], hoping to clean the carburetor jets. Finally, this winter, I removed the intake manifold and one-by-one cleaned the carburetors in carburetor solvent. This weekend, I reassembled the entire system and bolted it back onto the engine.I was able to test it Sunday. The improvement was astounding. The engine responded like new. Accelerated [without] hesitation and moved right up to its redline. Anyone with similar carburtor performance should abandon additives and go straight to the root problem. Take the carbs off the engine and get them clean. A lot of work, but the only way to restore performance.
deepwater
posted 06-16-2008 03:37 PM ET (US)
Some times ya got to do it the old way,,after all that work i would still use [a fuel additive] to help keep it clean,, did you ever see the pic of the prop hub i posted ,,what seafoam cleaned out of my system was nasty looking and the 88 Johnson ran better every time i put in the water,, ill send ya a pic |
Bob of Glenburnie
posted 06-16-2008 05:04 PM ET (US)
[Suggested changing the topic of discussion. Please use the SEARCH function to locate many articles in the archives on your new topic.] |
posted 06-16-2008 09:39 PM ET (US)
Bob--Thanks for the report on the success of your carburetor cleaning project. Can you give us more details on the process? How far did you disassemble the carburetors? Were you guided by a procedure from a manual? |
bobgilsp
posted 06-17-2008 09:50 AM ET (US)
Deepwater-Yes, I saw the photo you posted a couple of years ago after you had de-carboned your '88 Johnson. After all the labor I devoted to cleaning my Keihin carbs, I will religiously use Stabil & Sea Foam to keep varnish from clogging them again. Disconnecting the fuel line & running the engine until it quits & then draining the carburetor bowls just isn't enough to keep the internal jets clean.Bob of Glenburnie--Many members of the forum (and mechanics)swear by Sea Foam to de-carboniize cylinders & to keep carbs clean. Run that word through the SEARCH function. You'll even see Sal Mercurio's technique for applying it. jimh- I wish I had access to the Honda shop manual for the BF90. I used a Selor manual that generically covers Honda outboards up to 2001. It wasn't helpful in getting the intake manifold/carburetor array/air intake off the engine. That was a struggle, particularly for the linkages to the throttles & chokes. The manual had an exploded view of the jets within the carbs. I didn't touch the pilot screw. Idle seemed ok & I didn't want to have to reinstall & adjust 4 of those things. All the jets I cleaned were accessed by removing the carb bowl. Removed 3 brass screws. The larger one covered the brass tube that runs vertically through the carb throat. That tube has an O-ring at the top. I didn't have to replace that O-ring, but I was careful to keep it out of the carb solvent. That tube was seated within a brass jet that didn't extend into the carb throat. In all, I had 5 brass components that I soaked several days in carb solvent. I didn't put the carb body into the solvent bucket. It has several plastic parts that would likely melt in that strong solvent. I did rinse the carb body with solvent. I blew out its passages with air as best I could. Didn't have an air compressor, so I used my 12 volt inflator. The needle valves for the carb floats werre all in good ahape. Didn't even need cleaning. Reassembling the 4 carbs to the intake manifold was difficult. Could have used 2 more hands. I now see why marine mechanics charge so much for rebuilding carburetors. Bob |
Mr C
posted 06-17-2008 12:38 PM ET (US)
Bob, Would you comment on performance numbers your seeing with the Honda? MPH, GPH at speed, trolling etc. I'm toying with the idea of repowering and carbed Honda 90's can be had for around $5500 from one of our local dealers. I currently have an '82 Johnson 90 and love the power. Thanks, Dave |
bobgilsp
posted 06-18-2008 02:20 PM ET (US)
Mr. C- I'm sorry I don't have any performance numbers to pass on to you. I didn't have my GPS connected & didn't have a flow meter. However, I think I can echo the sentiment of most Honda owners that the engines are fuel efficient, durable , & reliable. The 1.6 L engine that I have is based upon the old Civic CVCC block. The new 75/90 HP, 1.5 L engines are derived from the Honda Fit engine. Both of these automotive engines are known for quality & reliability. The new engine has fuel injection, 4 valves per cylinder, & variable electronic valve timing. It also weighs less. The older engines have a good repair record, as long as you keep the Keihin carbs clean.Bob
darylrl
posted 06-19-2008 08:13 AM ET (US)
This is good to hear. I have a 1998 bf90 on my montauk. She has a hick-up and miss at mid-power setting and farts a little bit upon acceleration. I have tried the magic bottle but no luck. Guess I will be taking off the carbs in the next day or 2. You say you did not have to replace any parts? What about gaskets or are the bowl seals an o-ring?Thanks, Daryl |
Tadpole
posted 06-19-2008 09:43 AM ET (US)
Since a "cleaning" with no parts replacement did the trick, "maybe" the following will help. I recently bought an 06 Merc 9.9 4 stroke for a song because the owner used it ONCE - and let it sit; the gas was now 2 years old. It was very hard to start, would not idle, and surged badly when it did run. I poured the two gallons of old gas in my truck - highly diluted - filled the Merc tank with a "top tier fuel" -google it. I used Shell V-power, and two ounces of Lucas fuel system cleaner. Two 30-40 minute sessions of running - in a trashcan - rather than "rabbit ears" and the motor is absolutely purring! Sure beat pulling the carb/carbs apart. Good luck. |
bobgilsp
posted 06-19-2008 04:51 PM ET (US)
Daryl- I was lucky with parts. The gaskets between the carbs & the manifold and between the carbs & the air intake came off pretty much intact. Needed only a little touch-up with gasket seal to be reused. The carb bowls are held on by 4 small bolts. Remove them & carefully separate the bowl from the carb. If you are lucky, the O-ring will not be disturbed. Mine were in good shape. Same with my floats & needle valves that control gas level in bowls.Tadpole- Your were lucky to clean out the Merc carb with only good gass & Lucas fuel cleaner. I used many applications of Sea Foam for minimal results. Once the carbs were disassembled, I could see why. There was varnish on the jets in places that an additive might never reach. Bob |
