Ridge Runner |
posted 07-03-2008 10:06 PM ET (US)
Boston Whaler does in right by using portable gas tanks on the deck. I bought a 1990 16' Wahoo! for my son to use, so I started to restore it, which includes a repower, So I figured 18 year old boat lets change the fuel lines, wasn't sure if they could handle ethanol or not. Forget about take out the old line; that was completly foam in, and the foam is as hard as concrete. So I had to cut 2 new access panel in, and using a electrical 72" drill bit, drilled a hole down the inside of the gunnels (drilled through the bilge pump discharge line; what fun!), then came through the battery box in the stern (I moved the battery to the center console). I went to the marine store 3 times, used 2 access plates, 2 thru-the hull fittings, 3/8 fuel line, ss fuel filter head, Yamaha 10 micron filter, a couple brass fittings, new primer bulb, tube of 5200, tube of silicone, 4" hole saw, 72" bit, 9- hose clamps, thread sealant, Yamaha fuel connect, bilge pump hose, nipple, ss screw's = $374 and 8 hours later, who says a built in fuel tank is a plus.
