posted 11-03-2008 07:25 PM ET (US)
Low compression in one cylinder is generally caused by one of three things:1. Damaged or blown head gasket. This would usually lead to zero compression on that cylinder. But it's also the cheapest and easiest to assess and, if necessary, repair. It can generally be done by your average Joe in his driveway in about 30 minutes, unless the head or block surface needs to be machined, which can get more complicated.
2. Scored cylinder wall. This can be assessed when the head is removed at no additional expense or effort. However, repair is much more costly. It is not, however, anywhere near as expensive as replacing the engine. I spent about $2,000 on a complete rebuild. Aside from machining, I did all the labor myself. It took me about three man-days of work to tear it down and rebuild it. It's not something just anyone can do, but if you've got a buddy who's done some engine work, you might be able to enlist his help. Otherwise, figure another $1,000 for your neighborhood shade-tree mechanic to do the whole thing. The machinist who did my heads and block (and through whom I ordered my parts) informed me after the fact that he would have assembled the block for me for $300. Although I was able to do it myself, I wished I'd paid him. For that price, it simply would have been worth it, both for my time and peace of mind.
3. Broken or worn piston ring. Usually a worn piston ring goes hand in hand with a scored cylinder wall. It's a sort of chicken/egg thing. But rings can break without damaging the cylinder wall, causing a small loss of compression. Count yourself very luck if this is the case, and get it repaired right away. You will only have to remove the block and pull the one damaged piston. Still a lot of work, but a lot less than a complete rebuild.
Repairing just one piston/cylinder can be done, however, these failures usually only happen on older motors, or motors that have experienced a lack of lubrication or cooling. So, knowing that, most people opt to rebuild the entire engine, since it's not a whole lot of extra expense and zero extra effort once you've got the block disassembled for machining. And, truth be told, since you need to remove all pistons for machining, it's too risky to attempt to put the old pistons, rings and bearings back in. If you swap one part for another on accident, you can have a problem, since not all parts will wear evenly, and you open up the opportunity for a compression leak or increased wear on a bearing. It can be VERY difficult to keep track of where each and every part went, and which way it was oriented. They all look the same, but the microscopic wear patterns are very different indeed.
If you indeed find a scored cylinder, on that new of a motor I would rebuild. But I would rebuild the whole thing, not just one; for the reasons above, plus the possibility that one or all of the other cylinders are also worn, and are just barely still making compression.
You should not need to re-sleeve unless the engine has been rebuilt and bored out multiple times before. If you do, you will then want to weigh the cost of a new powerhead vs. a whole new motor.
