posted 11-12-2008 09:08 PM ET (US)
Hi OEB, While unlikely, it is possible your Mercury has a corrosion problem. I have seen this problem with an 2001 Yamaha F100 which has the same powerhead as your Mercury. The use and service history was not known for that engine and a factory defect was also a possible cause. Regardless, the engine did not run properly and that is how the problem was discovered. Is your mechanic confident that it's water in the oil and not fuel? How often have the anodes in the cylinder head and water jacket been replaced? How often is the engine oil changed? Is the boat left in the water during the boating season and if so, is the motor left down or tilted when not in use? Your mechanic likely removed your spark plugs to spray storage fogging oil into the cylinders. At this time did he notice any evidence of water fouling on the spark plugs? If any cylinder shows signs of a problem, it would likely be the bottom cylinder.
I doubt you have a corrosion problem though, it's not common. I would do more investigating to determine the cause. Has the engine's compression been checked reciently?
As a note; I have the 2004 version of your motor on my Outrage and I've been quite pleased with it. Lots of saltwater hours on it.
- Chris
