posted 12-17-2008 12:45 PM ET (US)
Read thru this post & you may get some ideas now that you have the tank out.http://continuouswave.com/ubb/Forum3/HTML/014506.html
Mine was a 32 gal. tank for a 1993 outrage. As I recall the freight was about $125. FMT has 2 plants. If you can get them to make & ship from the one closest to you it will save you freight.
I did not pay to have FMT paint my tank. I bought special paint and did it myself. If I had to do it again I'd pay and let FMT do it. I did a great job but the cost of the paint and the time it took wasn't worth the difference in cost.
This is a cut & paste from the quote I received from FMT
"...Replacement tank model FMT-34-BWE [1993 17' Outrage]will cost $350 and it will be made from 1/8" Aluminum (we no longer use .090").
- Tank is manufactured out of 5052-H32 Aluminum Alloy.
- Terms are payment in full (we do not accept credit cards).
- Lead-time: 4 weeks after we receive full payment. (3 week min. upon drawing approval)
- Tanks are quoted FOB Henderson, NC or Dexter, MO
- Shipping is not included nor estimated by FMT. Tanks are shipped freight collect.
- This quote is based exclusively on the information contained on drawing.
Revisions and/or variations from this information may invalidate this quote.
- Tanks are quoted with pickup, fill, & vent NPTF fitting welded, and electric sending unit.
- We no longer stock or purchase Wema and Rochester Twin-Site senders.
- To ensure the structural integrity and safety of our product, F.M.T.requires mounting information (via drawing, video, and/or written explanation). F.M.T. engineering will assist in advising acceptable mounting modes should you require it.
- FMT recommends tank to have a fully supported bottom with ¼” neoprene
rubber strips separating tank with support, and tank to be strapped or bracketed down.
- Tank is not designed for high performance use (application 55 MPH or greater)
- Quote valid for 60 days.
- Send payment to:
Florida Marine Tanks, Inc.
PO Box 222980, Hollywood, Fl 33022
Andrew Johnson, Engineering Assistant, 120 Peter Gill Road, Henderson, NC 27537
Phone: 305-620-9030, Fax: 252-438-4094, ajohnson@fmtanks.com
www.floridamarinetanks.com"
___________________________________________
This is a cut & paste from the information on the paint that I used. Jim is great to work with!
"Boat - CeRam-Kote 99M Paint
edboat@aol.com
Jim Edwards
Used to coat aluminum gas tank for boat
Sand aluminum tank well with 40 grit paper then wipe off with ACETOME before painting.
Do not paint if temp is below 55 deg.
Use 3/8" nap roller compatable for epoxy paint
1st coat let dry until tacky but doesn't come off when touched
2nd coat about 2 hours with temperature at about 65 - 70 deg.
You Will need to apply 2 coats of CK 99M. The best preparation for a new tank is to sand blast the tank, if that is not possible the tank must be sanded VERY WELL with 40 grit sandpaper. Wipe down with acetone and apply the first coat of coating then wait until the coating is tacky but will not come off on your finger apply the second coat of coating. Let the coating dry for a day and then put your tank in the boat. A quart of CeRam-Kote will coat 25 sq. ft. at 2 coats
CeRam-Kote 99M can be rolled. I recommend a 3/8 in nap roller to give you the mil age you need. Roll the first coat on well but don't back roll very much as that reduces the mil age on the surface. Apply the second coat approx. 2 hours after the first coat. Us a roller compatible with epoxy. Make sure the temp is above 55 when you apply. The colder the longer between coats. If the temp is around 65 to 70 do the second coat in 2 hours. If you have any questions when you are applying the coating call me. I don't know what other type of primer you will be using but if it is an epoxy it will be OK...."
This is the information for the foam that I used. I used one quart of foam. You will need 2 quarts for the 19 ft.
US Composites
Phone No. 561-588-1001
Fax No. 561-585-8583
Office Hours - Monday thru Friday 9am to 5pm Eastern Time
Mailing & Physical Address:
5101 Georgia Avenue
West Palm Beach, FL 33405
Ordering:
You can order your products online at our secure site. Orders can be faxed to 561-585-8583 or you may phone your order to 561-588-1001.
4 lb. Density Urethane Foam #0404, 1 Qt. makes 1 cubic Ft. $19.75
Ordered 1 quart Feb. 29, 2008
#435 Polyester resin (use to coat exposed foam surface) ~ $12.50
Ordered 1 Quart Feb. 29, 2008
Good luck!
