posted 02-03-2009 03:25 PM ET (US)
Beantown -I have two 2006 90-HP E-TEC motors. I've not noticed any black or oil residue on my gear cases after winterization, however, I do store the engines tilted back down to almost vertical instead of up. The skegs are resting on small blocks of wood on the floor (to keep from damage) so that the tilt ram is mostly protected inside the housing. The manual also recommends storing the engines in a vertical position.
You should inspect the residue carefully. If you changed the lower unit oil when you winterized the motor, is it possible that you failed to remove the o-ring on the gearcase?
The lower unit gear oil is not scheduled to be replaced for 300 hours, but I change mine annually due to the freeze/thaw cycle we have here in the northland. I figure never hurts to be sure.
Incidentally, the lower unit gear oil is green/blue and will come out a light green/cloudy if it has water in it. If your gear oil is creme/caramel or amber like traditional oil, you are using, or your dealer is using, the wrong stuff - make him change it to the spec'd high performance stuff.
It sounds to me like you are seeing carbon, which is normal in a traditional 2-stroke engine, but a bit unusual (from my experience) for an E-TEC. Are you using xd-100 oil? If so, you should not have any carbon/ash in the exhaust hub unless you have overpropped the engine or overloaded the boat - and the engine is lugging. Under normal operation and with xd-100 you should have very little carbon build up.
I would take a photo and share it with your dealer to see what he has to say.
If I had to guess, I'd say that it is PROBABLY what others here have suggested, but my feeling is that the presence of that much carbon probably indicates another problem - or else is indicative of you burning a lower-quality oil in the motor.
Good luck - let us know what you find out.
Dave
