Topic: Battery Problem
ronniet |
posted 03-05-2009 12:22 PM ET (US)
My boat contians two batteries.The batteries are linked with a PERCO dial switch,Problem is only one baterry works! Dial position #1 works position #2 no.Both batteries are new and charged.I wonder if it could be linked wrong or the dial switch is faulty?possibly there is a fusable link that I did'nt see upon inspection of the battery cable's?Any thought's, Thanks Ron
Tohsgib
posted 03-05-2009 12:30 PM ET (US)
Those switches go bad. Pull it off and look for corrosion on the backside. |
ronniet
posted 03-05-2009 12:34 PM ET (US)
Do you mean remove the cover of the switch or the switch Itself. |
Tohsgib
posted 03-05-2009 12:36 PM ET (US)
Whatever it takes to get to the connections. |
ronniet
posted 03-05-2009 12:47 PM ET (US)
I have already removed the cover of the switch and it appeared to be clean.If I'm not mistaken there were some concealed connections on the mounted side of the switch!Ron |
