posted 03-13-2009 08:29 PM ET (US)
Hi Guys,I have just completed a Powerhead Rebuild on a 1999 135 Optimax. Everything seems fine, engine starts immediately and pumps plenty of water. I have checked Temperatures with an external thermometer and they seem fine. Alternator is charging. Pressure differential is OK as well 10 PSI (80 - 90). The only issue I have is that if I try to accelerate the engine does not respond. It idles fine but it will not increase RPM past idle.
Unfortunately although I have a DDT I only have the Smatcraft v1.3 Cartridge and I do not have the Outboard v 5 Cartridge needed to check this engine. Because of this I have not been able to troubleshoot this issue.
Can anyone point me in the right direction and tell me why this engine would not increase RPM? Could it be that a Guardian mode has kicked in? If so what should I be looking for without a DDT?
Thank you,
Adri
