posted 06-16-2009 10:35 AM ET (US)
IMO there are WAY too many fuel and tank problem threads.If you suspect fuel problems, I recommend the first thing to do is replace solid metal canister water separators with a RACOR water separator that has a sight glass and drain valve that will allow you to monitor the amount of water or gunk and drain it out.
S3213 fits 5/8 thread
S3227 fits 3/4 thread mount
Approx $40 per filter, sight glass is about the same price but removable and replaceable on a new canister.
These Racor filters are very efficient...and relatively expensive.
I have a dirty fuel tank so I clamped a $6.00 acorn filter into the fuel line between the pickup and Racor water separator to act as a pre-filter. Bring tools soap, absorbent rags, sealed jug to make removing the acorn filter and its contents simple and safe.
REGS FOR
Blowers.
Carb spark arrestors.
Marine compliant electronics.
JUNK FUEL
is dangerous...a bunch of BS.
Complain to Politicians and USCG that adding special filters and replacing them on boat to comply with ethanol issues is a serious safety hazard.
Again, DEQ has all these oil regs and recycle programs but no answer for disposing bad gas.
Everybody step back...I hesitated to even comment on these fuel threads...PLEASE be very careful.
