posted 06-25-2009 06:40 PM ET (US)
[A duplicate article on this exact topic was posted to another discussion area. That article and thread have been deleted. It would be greatly appreciated if authors avoid posting all of their articles in duplicate.--jimh.]I own a [1989--please use four digits to represent years] Montauk with a 2003 [Yamaha--please use the proper name of the manufacturer] 90-HP carburetor two-cycle motor. Starting the engine cold usually requires about five seconds of cranking. At that point the motor starts, it revs at 1,200-RPM or so, and drops to idle after 20 seconds. I understand the increased idle is [due to] "Primestart" enriching the mixture until the engine comes to temperature. All things considered, this is not bad. No chokes, no pushing the key or lifting a toggle. Just prime the bulb and turn the key; five seconds or so and it kicks.
However, I picked up for my father-in-law this winter a Bayliner 160 with a 2003 [Mercury--please use the full name of the manufacturer] 90-HP two-cycle carburetor motor. That engine requires a push of the key to inject fuel into the carburetors or manifold prior to the cold start. Once this is done, turn the key and it starts instantly! You pretty much don't even hear the starter engage and it's running. I don't recall if it fast idles on its own; I don't think it does. But--instantaneous cold start every time.
Is the [Yamaha motor] working properly? Is the [Mercury fuel enrichment for staring] just a different approach that seems more effective?
It seems [Yamaha] Primestart raises the idle RPM for at least five to ten seconds even if the engine is warm, making for some rough shifts if you're in a hurry. Is this normal? [Give me your] thoughts [about the normalcy of the Yamaha starting with enriched fuel when warm causing rough shifts]?
Thanks--Jim.
