posted 07-13-2009 03:05 PM ET (US)
I had opportunity to spend a week in Michigan’s beautiful Upper Peninsula archipelago of the Les Cheneaux Islands over the past week. Of course, I took the Whaler.The trip was a family reunion of sorts, and we had rented a beautiful little cabin in Hessel, Michigan for the week to house my mother, grandmother, brother, sister, brother-in-law and his parents. With 8 people and 4 dogs, we were a crowded house.
A secondary purpose of the trip was to make delivery of a restored 1968 Starcraft 16 ft. fishing boat to my brother.
We had fully fueled the boats on Friday in lower Michigan to take advantage of lower fuel prices and upon arrival, I launched the boat and discovered a bilge sump filled to the top with raw fuel.
My first thought was that my fuel tank had corroded through, and the damage had finally caused the container to burst forth with fuel. The second thought was a broken seal/gasket. I checked both and did not find any problems. Having cleaned up the Whaler, and having nowhere to put it except for the cottage we rented for the week, I proceeded to the dock and got busy figuring with other things. When I returned to the boat, no new fuel had accumulated in the bilge, despite having been run a few miles, and having people in and out of the boat (and very full tank) sloshing it around. So…I went for a spin to see if I could get more fuel to leak so I’d have a freshly wet area to investigate. No joy.
Given that there was no more apparent leakage, I proceeded to use the boat on the calm waters of the Les Cheneaux Islands and did some fishing and even went to see the fireworks (albeit at a slightly increased distance – I’m a risk taker, for sure, but not quite THAT much risk).
Anyway….after draining the tank a bit through use, I continued to be worried about the boat. I have a trip planned for later in the summer, and if fuel is getting out, water can get in….and I needed to find the problem and solve it!
My brother, Pat and I pulled the boat to the dock and I added 5 gallons of fuel from a jerry can we had standing by. Shortly afterwards, more fuel appeared in the bilge – but this time, the tank was not very full. AHA!!! I had some direction!
I pulled the deck plate and re-checked the seal at the fuel fill hose connection to the tank – dry with no smell of gas. Next, I pulled the access panel under the fuel fill plate on the gunnel and checked that connection – tight and dry – but the smell of gas was strong, and the rigging tunnel was wet. I carefully felt the 1 ½ inch fuel fill hose (which I had replaced in 2006 with the new teak deck, new engines, etc). I could feel cracks and softness in the hose. Right at the elbow I felt a hole about the size of my thumb. I had found the problem! I cleaned the rigging tunnel – searching for a screw or nail or anything that might have caused a vibration wear on the hose – but found nothing but some leaf litter and gradu from several years of fishing. No hooks or anything…just mushy black stuff.
Anyway – I had my problem and now I knew the solution. I went to the Marina and bought a length of hose and returned to the boat…..where in my excitement, I failed to measure twice and cut once! I had bought the last few feet of hose from the marina, and cut it too short! D’OH!
Grasping the situation, I went to the OTHER marina in town and killed an hour while they sold me a section of wet exhaust hose. When I pointed out the mis-match, the owner slapped his forehead and informed me that they didn’t have fuel-grade hose in stock. The nearest marina with some was in Mackinaw City – 24-some miles by water and 37 miles (plus tolls) by car.
This won’t surprise those of you who know me, but I packed up the boat, stripped down the extra weight of fishing gear, etc and set off by water to Mackinaw City for the replacement hose, which I installed on-the-spot at the courtesy dock for the ramp.
Why waste a day on the water to do boat chores when you can combine trips and have a great day on the water?
Anyway – check those fuel hoses – like your stickers say – at least annually. This was a new hose and I believe that the ethanol fuel that sits in the elbow “ate through it” in less than three years.
This is an easy and inexpensive hose to replace.
