ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Locktite for Jack Plate Fasteners
Author | Topic: Locktite for Jack Plate Fasteners |
bang4dabuck |
posted 07-17-2009 06:19 AM ET (US)
Put a six-inch jack plate on my Katama and a 90-HP on that. Should I use Locktite on nuts on both plate to hull and motor to plate? If so, red or blue? |
rtk |
posted 07-17-2009 07:56 AM ET (US)
I didn't use anything on my CMC jack plate install because lockwashers or locknuts were provided. If you are going to use locktite threadlocker use the blue. Rich |
Tohsgib |
posted 07-17-2009 01:46 PM ET (US)
Should not need it..too many bolts have to be loosened for it to move. I actually put greese on mine so they would not weld shut. |
pglein |
posted 07-17-2009 04:17 PM ET (US)
I would just use lock-nuts. |
L H G |
posted 07-17-2009 05:10 PM ET (US)
The professional way to mount engines and jackplates is to use the same components that Mercury furnishes with new engines: * Fine thread 1/2" SS bolts of correct length Last three items are hard to find, but the fine thread bolts can be found at Ace Hardware. No threadlocker should be used. |
bang4dabuck |
posted 07-18-2009 07:01 AM ET (US)
I got my plate off Ebay without hardware (Rite-Hite). Pretty sure though that CMC does not use lock nuts. Got to admit I got my hardware from the Lowes stainless drawers. I will look for appropriate lock-nuts and if no luck will use Locktite blue. |
L H G |
posted 07-20-2009 01:57 PM ET (US)
Here is once source for bolts sets for proper outboard installations: http://www.detwilerjackplates.com/jack_plate_accessories.htm . |
Tom W Clark |
posted 07-20-2009 03:55 PM ET (US)
What Larry refers to as "...very small diameter 'ring' washer" is more commonly known as an SAE (specification Washer). Any good hardware store will have these. The locknuts that Mercury uses are brass, not bronze. Fine thread versions are hard to find. Stainless steel locknuts will be a better choice for saltwater use though you need to tighten them by hand to avoid galling. Grease or anti-seize will provide additional protection against galling. If you do not live near a good hardware store, you can always order any obscure hardware you might need from McMaster-Carr: |
