posted 07-31-2009 04:33 PM ET (US)
I've got a question for the group. Here's the story:Bought a boat/motor/trailer combination back in Fall 2004. Trailer contained (2) new 13" tires. While checking the tire pressure yesterday, I noticed that the driver's side tire was wearing disproportionally on the inside. I don't recall ever running over anything and given the fact that the tires were new when I purchased the package, it took a while to actually produce the tire wear to a point where I would notice.
Now...I measured from the hanger hardware (holding the springs to the frame) to the back portion of the frame. Both sides are the same. What other measurements should I take to confirm if the axle is too far forward/back on the frame? I think I did that already but I want to confirm.
If it is the spindle or the actual end portion of the axle which is bent, what can be done? I read on another continuouswave.com thread that a person here took the trailer to a tractor/trailer frame shop and had it aligned. So, I got a "ball park" quote (over the phone this afternoon) from Schimpf's in Camden, NJ for $150. It's close in terms of a dollar amount required to replace the axle, hubs, bearings, races, seals, and u-bolts/nyloc nuts (as the replacement axle is round and a different diameter or could be square; depends on the supplier). My current axle is round.
Looking for advise as to whether the frame shop is a better option or not?
Bob
