ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Renovating Canvas
Author | Topic: Renovating Canvas |
rollingrightalong |
posted 08-19-2009 02:07 AM ET (US)
I recently bought a 1988 V-20 which came with some canvas in good, but non-waterproof condition. I had a good friend steam pressure clean the canvas, although a good wash would probably do the same. Remember to fully remove any soap or detergent residue. Searching the internet for waterproofing ideas I came across a suggestion to use soybean oil cut with 50% (by fluid volume) turpentine, as an alternative to spray cans of waterproofer. It took a gallon (actually 3.5 litres) of soybean oil and 50% of that in turpentine, well mixed (shaken vigorously) in a used plastic milk jug to "paint" the whole cover. I actually used a small 6" wide roller and a 3" brush. It smelt initially of turpentine, which faded rapidly, but really kept the bugs away during application. I noted that the first rains washed away the excess oil. If anyone has done this please contact me and let me know if I'm headed towards disaster. |
posted 08-19-2009 07:12 AM ET (US)
Thanks for the interesting remedy. I do not recall prior reports of that technique. ASIDE: I am interested to learn more about a Boston Whaler V-20 hull made in 1988. Prior research has led us to believe that production of the V-20 hull ended in 1985. |
kazankota |
posted 08-19-2009 07:29 AM ET (US)
Nikwax cottonproof works well. I've used on other canvas products. Need to ensure all detergent residue is cleaned away. You can do it in the washing. |
Chesapeake |
posted 08-20-2009 10:15 AM ET (US)
Call Mills: I sent my mooring cover back to them and they cleaned it and followed up with a waterproof coating. I am sure they would tell you what spray they use for their tops. Bob |
Buckda |
posted 08-20-2009 12:23 PM ET (US)
I think it really depends on what material was used to make your canvas. If it was Sunbrella brand fabric, they recommend quote: cf: http://www.sunbrella.com/na/cc_marine_tops_covers.php They go on to recommend how to apply the product: quote: NOTE: They also recommend that you NOT steam clean the fabric: quote: |
Don88outrage |
posted 08-20-2009 04:33 PM ET (US)
Interesting process, sounds like it has roots going back to the old rain gear used by commercial fisherman, if I remember correctly they we're called oil skins, and the old canvas tents that we're treated by a gooey waterproof recipe. |
Chesapeake |
posted 08-22-2009 11:39 AM ET (US)
Dave: Great post. Last night I went into my "solvents cabinet" to check the bottle of waterproofing solution that Mills sent to me... you guessed it: 303 brand. |
rollingrightalong |
posted 05-26-2011 10:22 AM ET (US)
It's 18 months (and two north-west rainy winters) since my first post on this 'waterproofing' technique. As a follow-up I can report that the canvas is still fully waterproof (and holds ponded rainwater when I forget to install the support frame at the stern) and shows no signs of fading from the 'darkened' blue the treatment created. The only downside was that some of the soy bean oil / turpentine mixture dripped onto the fiberglass which has meant a little bit of easy cleaning maintenance with methyl hydrate. No lasting damage. So far so good. Later this summer I'll ask my good friend with the commercial hot water / steam power washer to clean the canvas again to remove the grime build-up. I'll report back if this causes the canvas to require re-waterproofing. |
