ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods DAUNTLESS 16 Deck Drains with Check Valves
Author | Topic: DAUNTLESS 16 Deck Drains with Check Valves |
East Bay |
posted 08-29-2009 12:50 PM ET (US)
I have a Dauntless 16, and someone, somewhere on this site mentioned a ping-pong type [drain with check valve] that would work well on my boat, and would be easy to install. Anyone remember what it was, and where I could purchase it? Thanks! |
Phil T |
posted 08-29-2009 03:06 PM ET (US)
EB - I think they were suggesting ball type scuppers. One example: |
number9 |
posted 08-29-2009 03:20 PM ET (US)
TH Marine also produces one available many places. |
fishgutz |
posted 08-29-2009 09:12 PM ET (US)
I guess those scuppers work good but on the cheap I cut apart a rubbermaid lid from something and made a ring with these tabs cut into it. They are set over the flap and really have worked well for me for years. The flaps just needed a little help staying closed. Water still flows out quickly. http://i42.photobucket.com/albums/e336/Fishgutz/Boat%20Tech%20Pics/ Scupper.jpg Just another CHEAP idea. |
fishgutz |
posted 08-29-2009 09:13 PM ET (US)
Oh, its the green part. |
East Bay |
posted 08-30-2009 04:36 PM ET (US)
Just so I get this right, you cut up a plastic cover (green), took off the plastic ring with the four screws, shaped the green plastic so the two small tabs (one on the upper left, and one on the upper right) hold the original black flapper more ridgid. Is that correct? |
fishgutz |
posted 08-30-2009 05:47 PM ET (US)
East Bay, You are absolutely correct. I'm cheap and ingenious. It has worked great for several years now. You could use a Cool Whip lid or a Tupperware lid. The rubbermaid one was a little thicker. Maybe 1/32 inch not quite 1/16 inch? I got the idea from some scupper company that makes theirs look like that. I don't know the company. Saw it somewhere. It took a couple tries until it worked perfectly. |
Nauti Tauk |
posted 08-31-2009 07:09 PM ET (US)
Hey Guts, that's really pretty kewl.....you did good! I'm a problem solving fabricator too. |
