posted 09-06-2009 01:10 PM ET (US)
I do not recommend operating the engine with the warning buzzer or aural alert disconnected.Try running the engine with the gear case submerged in a barrel of water. This will give you a better idea of how the cooling system is working. Running on a hose adaptor might be causing a problem.
Typically on a Mercury outboard there should be a flow of water from the cooling system aspirator once the engine jacket has filled with water. This often takes a minute or so to occur. If you never get any water from the aspirator, there must be something awry in the cooling system. Either the water pump cannot produce enough flow and pressure to raise the water to the power head, or you have a leak somewhere and the water is being diverted.
If the gear case was improperly assembled to the midsection, the water pump output may not be properly connected to the rest of the cooling system.
