posted 09-12-2009 10:26 AM ET (US)
I'm in the very early stages of rebuilding an old SPORT 13. The hull is from the mid-1970's and has a Desert Tan interior, and the motor is a late-1990's Mercury classic 40-HP, four cylinder two-cycle. This boat was my dad's and when he passed away about ten years ago it was given to me. This hull has an interesting past, and I'd like to get some opinions on what I should do with it. My dad originally bought this boat with a mid-1970's Evinrude 25---probably the original motor. The Evinrude was in rough shape and a few years later he decided to repower it with the Mercury I mentioned above. The Mercury was installed by the dealer that it was purchased from. At the same time the motor was installed, new controls and a teleflex system were installed. Shortly after repowering it, my brother had an accident with the boat that left the hull badly damaged (he was OK but shaken up). Sparing the details of the accident, the boat hit a dock at fairly high speed which took a huge gouge out of the hull. My father had the hull professionally repaired shortly after the accident, and it now looks as good as new. I can't even see where the repair work was done, and I remember being told that the repair was done following Boston Whaler's recommended procedures.
The boat was never actually put back in the water after the repair work was done, and since then it has been sitting in my garage collecting dust. I've recently decided to get this rig up and running again for use on freshwater lakes and rivers in my area.
I've stripped the boat of everything except for the motor. After a quick cleaning and inspection, there are a number of screw holes and other small nicks from normal wear and tear that I'll need to patch. I've already received guidance here on these forums about how to do this (never worked on fiberglass before - should be interesting!!). My concern however is that there are a lot of cracks in the gelcoat, some of which are fairly large. These cracks seem to be located near joints, which is also a little curious. How concerned should I be about these? I know this is a hard question to answer without actually seeing the boat, but given the boat's history, would I be better off finding another hull altogether? I also don't have many details on the original hull repair, so it's hard for me to know how well it was actually done.
I want to make sure that the boat is seaworthy and safe - that's my first priority. This hull is in otherwise good shape, much better than many of the ones people here have brought back to life, but the history and prior damage scare me a little. I've also considered bringing this to a professional to have all of the problems mentioned above taken care of. This might not make the most economic sense though - I'd probably be better off just getting a new hull in good shape.
I'd love to hear some opinions on this. Thanks for reading!
