ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods c.2001 Mercury 90-HP ELTPO
Author | Topic: c.2001 Mercury 90-HP ELTPO |
scott c |
posted 10-10-2009 08:32 AM ET (US)
I just bought my first [Boston Whaler boat], a 2001 Dauntless 16, and it has a 2001 [Mercury] 90-HP ELPTO motor. Looking for an owner's manual. I know nothing about this motor other than it work well. Thanks--sc |
posted 10-10-2009 09:25 AM ET (US)
You can generally purchase literature for your Mercury engine from a Mercury dealer. Usually they have literature for engines going back at least ten years. |
Newtauk1 |
posted 10-10-2009 11:32 AM ET (US)
General Specifications on Mercury 2001 90hp 2 stroke: Full throttle rpm range: Kilowatts: # of cylinders:(3) Piston Displacement:84.57 cu. in. (1385.8cc) Cylinder Bore: 3.500 in. (88.9mm) Stroke: same 2.930 in. (74mm) Spark Plug: NGK BUZHW-2 or BUHW-2 Gear Ratio: 2.3:1 Weight 305#'s |
number9 |
posted 10-10-2009 12:03 PM ET (US)
Below are links that should work to download the manuals. Included are both 2 & 4-stroke models. http://www.brunswickmarineemea.com/filereader/file/pdf/4/enen/outboard/ 2001/2-stroke/10180z10.pdf |
number9 |
posted 10-10-2009 12:08 PM ET (US)
Second link was bad, if you need the 4-stroke here's for 2002. http://www.brunswickmarineemea.com/filereader/file/pdf/4/enen/outboard/ 2002/4-stroke/10215z20.pdf |
scott c |
posted 10-12-2009 07:50 AM ET (US)
Thanks to everyone who provided good info. I'm excited about my new to me whaler. Scott |
