| Author | Topic: New Moeller 24-Gallon Tank for 150 and 170 Montauk |
| 95Outrage17 |
I was searching around for under-RPS fuel tank options for a client's 2003 Montauk 170 and I came across this: http://www.moellermarine.com/aftermarket/fuel_storage_tanks/ topside_tanks Check out the 24 gallon white tank (Product # 031626). I couldn't find this tank mentioned anywhere. Does anyone have one? I'd be very interested in seeing pictures and knowing its cost. One problem I have on this particular Montauk is the fact that I installed a Racor filter under the RPS on the starboard side a few years ago. I'd like to leave it there, but I may have to relocate it to make the 24 gallon tank fit. I know there has been a lot of discussion about larger fuel tanks for Montauks, but is this Moeller 24 gallon something new? - Chris |
| Phil T |
Chris--I think someone has been reading the threads. The description states it is was designed for 15' and 17' Montauks. I say move the filter. Regards. |
| 95Outrage17 |
Hi Phil--Yeah, it looks that way. I'd say it's about time as it's a common upgrade. As for the filter; I guess I'll have to move it to the splash well area as others have done. Hope you're still enjoying the Outrage 17! I was out in mine today, it was a bit chilly. The temperatures here have been unseasonably low lately. Another side note; I've got three Montauks, a V-20, an Outrage 18 and a classic 13 in the yard right now :) - Chris |
| Nauti Tauk |
I made the switch from the Pate fiberglass tank to the red 26 gallon Moeler several months ago. One nice thing about the red tank is the ability to see the fuel level through the tank from outside the boat without boarding to look at the fuel guage. I wonder if the same will be true of the new white tank. I also had my filter/seperator under the RPS while I was using the twin 7 gallon tanks prior to the larger tank being installed and had to be relocated. The filter fits very well on the inside of the motor splash well on the starboard face. That location seemed to be the least obtrusive to me and has worked out fine. If the white tank had been available when I made my upgrade It would have absolutely been my first choice. We have a 2003 170 Montauk. Good luck. |
| Anjin |
I have a Montauk 17; a few years ago I opted for the Tempo 26 which is infamous for its tendency to leak. This tank is otherwise perfect and fits under the seat perfectly so that the fill neck is easily accessible without moving the tank. I am going to have to get a new tank sooner or later. The last time I looked (and it has been awhile) Moeller only had a 26 or 27 gallon tank that was problematic for a Whaler because the seat is too low and the fill neck was inaccessible. The link in this thread shows two tanks by moeller that now say "specifically designed for Boston whaler." (That is what the Tempo product description used to say and that is why I buoght it); A white 24 and a red 26. A question about the white 24: The description says "specifically designed for use in Boston Whaler ... consoles." Do you all understand that this tank is designed to be installed inside a console ? (is that why it is white?); and that the red 26 gallon tank is designed for installation under the seat? But they are both almost the same size (actually the white tank is an inch and a half wider yet holds two gallons less). ?? Does anyone know how these Moeller tanks compare with the Tempo 26 for how well it fits under an original unmodified seat and accessibility of the fill neck without moving the tank?
| 95Outrage17 |
Anjin, I have the same questions. I think the statement "specifically designed for use in Boston Whaler ... consoles" is a typo and they are in fact designed for under the RPS. That would make more sense to me. I'm going to take some measurements to be sure. I also think the greater width includes the protrusion for the filler and fuel fitting. That would explain the 24 vs 26 gallon capacity. - Chris |
| Anjin |
I went out and measured my Tempo 26. It is 29.50 L x 19 W x 13.25 H (to the edge of the tank; it is 14.25 at the highest point which is the fuel connector). This is almost identical to the red Moeller 26 gal. tank. Also from the picture of the Moeller tank it looks like the fill neck is positioned at the same place on that tank as the fill neck on the Tempo 26 tank. Seems like the Moeller tank should fit just right I think you are right about the typo. I think they are trying to say that these tanks are for use in Boston Whaler center console boats. |
| grocks |
Do you thonk these new 24 gallon white tanks will allow easy filling of fuel without needing to move the tank out from under the Montauk seat? |
| 95Outrage17 |
grocks, I think that is why the filler neck on the 24 gallon tank is angled outward. This allows the filler to protrude beyond the back of the RPS and therefore allows the tank to be filled in position. I wonder if the tank interferes with the fuel line where it exits the floor? I think it would on a classic Montauk, but possibly not on the newer Montauk 170. - Chris |
| Dave Sutton |
"The last time I looked (and it has been awhile) Moeller only had a 26 or 27 gallon tank that was problematic for a Whaler because the seat is too low and the fill neck was inaccessible." NONSENSE!!! Why does this incorrect rumor persist? They fit PERFECTLY under the RPS. Just slide the tank aft three inches to fill it. It's REALLY easy to do.
Dave . |
| wbullwin |
Early this year I installed a Moeller 20 gallon tank under the RPS. I have seen the red 26 gallon tank installed but it sticks out the back of the RPS about 4". My 170 Montauk is a 2003 and the top of the RPS under the cushion has a plastic insert which was screwed in place, so I took out the screws and added a piano hinge and now it gives me a huge access door. I installed the 20 gallon tank with the fill cap towards the bow since I can open the new hinged hatch to fill the tank. In addition, there is about 3" or 4" from the top of the tank to the underside of the hatch which allows storage for lines, tackle, suntan lotion, etc. I think the 2002, 3, & 4 have this loose piece. With limited floor space in the 170 Montauk, I elected to give up a few gallons to keep the tank completely under the RPS. There are threads here where people have installed hatches on top of the RPS if you do a search. I looked at this link and this white tank was not available early in 2009. I'm sure it will fit fine but will take up floor space sticking out the back of the RPS. |
| 1980Montauk |
Has anyone found a price on the tank mentioned above? I've looked on line and can't find anyone who has it listed. Maybe it hasn't started to ship yet. Garey |
| 1980Montauk |
Never mind, I found it for $199.95. |
| Raaaaay |
Where did you find the tank for $199.95 (or is that Moeller suggested retail price) Will this same tank fit under a RPS on a 1973 Outrage. (I am in need of a tank for temporary use until I replace my inhull tank). My boat currently has an after market RPS but I recently purchased a used RPS that I am restoring and I want to make sure that this "white" Moeller will be the right tank for my restored RPS (this RPS has the underseat wood blocks to keep the pivot bars properly aligned and I am not sure if this restricts the usable height under the seat for a tank) |
| Anjin |
Nonsense? I don't know ... by problematic I mean not a perfect fit My Montauk has two stainless steel straps in front of the tank and two behind screwed to the floor so you can hook bungy cords to hold the tank down. Also my tank sits on original BW mats. I think the stainless steel straps are original also. The tank slides out that three inches easily enough when it is empty but after you fill it ( 25 gals x 6.5 lbs a gallon) and with the straps and the mats on the deck it is not so easy to slide back. I went out and did some more measuring ... the space in the BW mats in which the original Pate (and the Tempo 26)tank sits is 18.5 inches wide; the fore-aft distance between the straps on the deck is 20.5 inches. The white Moeller 24 will fit between the straps but not in the 18.5 inch space in the mats. To use the Moeller white 24 you can't use the original mats .... If you don't use the original mats the Moeller will ride on the plastic hawse pipe and not sit squarely on the deck (another perhaps minor problem). The Tempo 26 sits on the mats like the original Pate 26 and sticks out the back of the seat about 3 inches ... but the Tempo is notched on the bottom aft section so that the fuel hose can come out of the hawse pipe uninterrupted. Neither the white Moeller 24 nor the red 26 have notches (according to the pictures in the link) on the bottom aft so both Moeller tanks will interfere with the fuel line coming out the hawse pipe (another more substantial problem). How are you guys using Moeller tanks routing the fuel lines? Conclusion (and I would like to hear how I am wrong): All the Moeller tanks are "problematic" in one way or another for the Whaler Classic Montauks (I don't know about the 170s). And none of them fit as perfectly as the original Pate or the leaky Tempo 26 which never had to be moved in normal operation once installed. |
| contender |
95Outrage17: Why do you not look into having a custom alum. tank made? Custom tanks in South Fla. usually go for about 8-12 dollars a gallon depending on the shape. Comes with a vent, fuel fill, fuel pick up and gauge (mech or ele.).... Think about it |
| Phil T |
Contender- Chris is in Nova Scotia, Canada. Not sure a custom tank shipped from Florida would be cost effective. I recall he contacted FMT for shipping a under-deck tank and the shipping was brutal. I think this new Moeller model has several changes to address complaints expressed by Whaler owners. - Color more attractive |
| 95Outrage17 |
contender, Phil is correct. Shipping such a tank from Florida to me in Nova Scotia would be expensive, but I could look into having something made locally. I had a new tank for an Outrage 18 made locally last winter, but it wasn't cheap. A lot nicer then the original though. I'd rather a plastic tank anyway and I think the new Moeller 24 gallon tank would look great under the Montauk 170 RPS. It would be nice to be able to have a sender and gauge on the dash, but I think they can live without. I'm going to check with one of my suppliers who sells Moeller products and see what the new tank costs and it's availability. - Chris |
| 1980Montauk |
Raaaay-This is the place I found it online. http://www.foreandaftmarine.com/FUELTANKABOVEDECK.htm Its shows list as $226.36. I don't know anything about the dealer. I just searched for Moeller and the model number. |
| Dave Sutton |
"Conclusion (and I would like to hear how I am wrong): All the Moeller tanks are "problematic" in one way or another for the Whaler Classic Montauks"
The tank fits under the RPS of my 1987 Montauk with about two inches of protrusion back past the seat, which is *exactly the same protrusion as the original dual tank installation*. Because: It fits the original mats *perfectly*, as long as you take the 30 seconds needed with a razor knife to cut the inner lips of the mats ut (they were designed for two smaller tanks). BTW: You need to do this with ALL single tank installations. Bottom line: A tank that fits the original mats has, BY DFINITION the same exact footprint as the original dual tank installation. So much for the nonexistant "Overhang" issues.
As far as strapping the tank down... don't bother. The mats will hold the tank perfectly. I run in the open ocean, and in heavy chop on a daily basis here and my tank has never slid a fraction of an inch aft. If you feel like it, run a bungee around the tank and the RPS legs. Hook one end of the bungee into the (original) stainless steel strapping-points and lead them around the RPS legs. Works perfectly. Filling... uh.... you generallly slide them back to fill them when they are only partially filled (duh), and it's easy to do. Sliding the filled tank forward is equally easy: The Moellers have a molded in grip area down near the bottom on the sides: Just kneel down behind the tank, grap it, and slide it forwards. It's far easier to do than to say.
Pate, Tempo, and Moeller: Been there, done that. Moellers are the best bang for the buck and are trouble free. I'll shoot pics if anyone wants them.
| swist |
As many have said, the old Moeller 26 fits pretty well, and I completely agree it's trivial to move it a couple inches back to fill it. I don't have any pads (170 Montauk) and I use two strong bungees horizontally across the back of the tank to keep it in place. I'm pretty sure I paid in the vicinity of $130 for it two years ago. Why would I buy a tank with 2 gal less capacity for $200 or more? "Custom fits Boston Whaler" for some companies is a euphemism for "We can charge you more because your boat is expensive". |
| Blackduck |
This looks like a good tank for under a RPS, I think I would go for it in that application, the best solution, at a reasonable price, I have seen to date. |
| contender |
95Outrage17: Sorry did not know you lived in Canada and I understand the shipping costs can kill you. However, there still should be someone some shop up there that welds alum. (metal shop, aircraft repair, boat yards). This might be worth you doing some home work. You can have your filler, vent, gauage even tie downs welded/place anywhere you want on the tank. There is even one type of mechanical sending unit that mounts on the side of the tank, so you can see it when you place the tank under a seat. Or you can even have an electrical unit and a mechanical unit mounted on your tank. As far as the color you can paint, or have the tank powered coated to the color of your dream. I have also found the kitchen/dinner rubber place mats work great for holding/stopping something from sliding on your deck. You can purchase the mat in rolls at Walmart, Home Depot, and probably any hardware store. I personally do not like plastic tanks, I do not think they are as safe as an aluminum plus the sun down here makes the plastic discolor and brittle which can cause a tank failure. What ever to each its own.....Take care |
| number9 |
I'll be looking forward to seeing some photos of the new Moeller tank installation. It may make an excellent aux tank for Outrages equipped with the RPS. |
| Anjin |
Well I am glad I am wrong .... I'd also like to see pics of the tank installation and how there is room for the fuel line to come out of the tunnel. And I'd like to see pics of the modified mats as well. I agree about the Tempo tank being a piece of crap but no modification of the mats was needed for that tank. |
| Dave Sutton |
Ah HA!! Read this carefully: "Specifically designed for use in Boston Whaler Montauk 15' and 17' CONSOLES"
This tank is smaller than the 26 so it can fit into the CONSOLE and not under the RPS.
| Anjin |
Hey Dave (are you the Long Island sound striper diver?) The fine print has already been read and the inside the console issue has already been discussed above. 95outrage and I think it is a mistake in the ad. How about the pics of your tank installation ... |
| 95Outrage17 |
contender, I certainly could have a custom tank made locally and thanks for the design suggestions. There are several good welding shops within a short distance. The shop that made the Outrage 18 replacement tank last winter did a great job. I had the tank powder coated after it was finished. Turned out great. So, I could go this route, but it would be expensive and I personally think a plastic tank would work fine in this situation. The sun is less of a concern here, plus the boat is completely covered from approximately November until May. Under the RPS on the 170 it will not get a lot of sun exposure (closed on three sides) in the summer and the RPS cover will help shade it as well. I'm not overly concerned about the sun and more about corrosion, appearance and the tank fitting properly. I don't think having to use the fuel gauge on the tank will be a big deal as it's an above deck tank. - Chris |
| swist |
I don't know about the new tank, but the old Moeller 26 has a fuel gauge built into the fill cap - mechanically driven by a float mechanism which comes is part of the cap assembly. I've found this gauge to actually work pretty well (although small boat fuel gauges of any kind are not a tough act to follow). And as someone pointed out you can double check it because the fuel level is visible, under the right lighting conditions, through the plastic. Not as slick as the clear strip molded into the Pate tanks, but it works. |
| GreatBayNH |
"Specifically designed for use in Boston Whaler Montauk 15' and 17' consoles" Two things I take away from this statement. 1) As mentioned above this was most likely meant to read center console boats and.. 2) Since they mention 15' and 17' together, and the 15' Montauk came out in 2006, that this tank was designed for 150 and 170 Montauks. That said I take the statement to mean: "Specifically designed for use in Boston Whaler Montauk 150 and 170 center console boats" |
| johnhenry |
Fore and aft marine seems to be the only online source for the white 24 gallon tank. I wonder if that is because it just came on the market? I think it looks a lot better than the red tanks. Maybe this winter the price will go down below $199, otherwise I might just buy it anyway. |
| Dave Sutton |
Anjin wrote: "Hey Dave (are you the Long Island sound striper diver?)"
As for the tank, what's being said makes sense. The new tank has an angled filler that would seem to make it possible to fill it without sliding it aft, but... why bother since it's really not an issue.
| Dave Sutton |
Forgot: Who has a photobucket account so I can send them a picture of my tank installation for posting so it can be seen by the gang?
| Anjin |
Dave: I remember you posted some pics of the stripers a year or two ago in a controversial thread about the bow eye on a Montauk. If I remember right you even had some underwater pics of the fish. You also described the technique: you dive in rough water in heavy current without air tanks, then the boat picks you up down current. My concern about the new Moeller tanks is about the fuel line. It seems the new tanks will cover the hawse pipe tunnel opening. I also wanted to see how you modified the mats. Did you just slice off the raised edge? |
| Dave Sutton |
Yup, that's me. We're still doing the same sort of diving. All I did was to slice off the inner raised lips, the ones that are for and aft on what would be the left side of the righ tank and the right side of the left tank. That allows the remaining periphery to hold the single Moeller tank in position and it fits perfectly. The rigging hole for the gas line has "just enough" clearance to allow a hose to be fed down thru it, if you take an extra 15 seconds to cut and remove one inch of the edge molding at the rear of the rigging hole. That needed to be done with the older Pate as well, and had been done on my boat years ago. At first blush you would think that sliding the tank aft over that hose feed-thru for filing would be an issue, but I can assure you that it is not. I'll take photos tomorrow if someone else wants to post them for me.
| Phil T |
Dave - Email me the photos and I will host them and post a link. |
